path: root/configs/pico-imx6ul_defconfig
2017-11-20pico-imx6ul: Add function to create gpt partitionsFabio Berton
Command run setup_emmc will create gpt partitions for mmc 0 device based on patitions variable. Signed-off-by: Fabio Berton <fabio.berton@ossystems.com.br> Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2017-11-20pico-imx6ul: Use PARTUUID to specify the rootfs locationFabio Berton
Currently the rootfs location is passed via mmcblk number and using the UUID method to specify the rootfs location is a better approach working even if mmcblk number for the eMMC changes depending on the kernel versions. Signed-off-by: Fabio Berton <fabio.berton@ossystems.com.br> Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
2017-10-03usb: gadget: Make g_dnl USB settings commonMaxime Ripard
The g_dnl USB settings for the vendor ID, product ID and manufacturer are actually common settings that can and should be shared by all the gadgets. Make them common by renaming them, and convert all the users. Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Lukasz Majewski <lukma@denx.de> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-08-07Move PHY_MICREL and PHY_MICREL_KSZ90X1 to KconfigAlexandru Gagniuc
2017-04-30Convert CONFIG_CMD_BMODE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_BMODE Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Make this default y and depend on mx5/6/7] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-26config: Move CONFIG_DEFAULT_FDT_FILE to defconfigsJagan Teki
- Add DEFAULT_FDT_FILE kconfig entry - Move CONFIG_DEFAULT_FDT_FILE from include/configs to defconfigs Cc: Tom Rini <trini@konsulko.com> Cc: Simon Glass <sjg@chromium.org> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2016-09-27dfu: Migrate to KconfigTom Rini
Introduce a hidden USB_FUNCTION_DFU Kconfig option and select it for CMD_DFU (as we must have the DFU command enabled to do anything DFU). Make all of the entries in drivers/dfu/Kconfig depend on CMD_DFU and add options for all of the back end choices that DFU can make use of. Cc: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Lukasz Majewski <l.majewski@samsung.com>
2016-07-12pico-imx6ul: Add DFU supportVanessa Maegima
DFU is a convenient way to program U-boot binary into the eMMC. Add support for it. Signed-off-by: Vanessa Maegima <vanessa.maegima@nxp.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-05-20pico-imx6ul: Select CONFIG_HUSH_PARSER optionFabio Estevam
Select CONFIG_HUSH_PARSER option in order to fix the following problem: Unknown command 'if' - try 'help' Unknown command 'then' - try 'help' Unknown command 'else' - try 'help' Unknown command 'fi' - try 'help' Reported-by: Daiane Angolini <daiane.angolini@nxp.com> Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Tested-by: Daiane Angolini <daiane.angolini@nxp.com>
2016-04-25pico-imx6ul: Update the defconfigTom Rini
The defconfig/config.h file were merged but were already out of sync with mainline. This brings them further into line now. Cc: Richard Hu <richard.hu@technexion.com> Cc: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2016-04-19Add initial support for Technexion's PICO-IMX6UL-EMMC boardFabio Estevam
Add support for Technexion's PICO-IMX6UL-EMMC board. For information about this board, please visit: http://www.technexion.com/products/pico/pico-som/pico-imx6-emmc Signed-off-by: Richard Hu <richard.hu@technexion.com> Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
