Done via moveconfig.py
Done with:
./tools/moveconfig.py BMP_16BPP BMP_24BPP BMP_32BPP
Done with:
./tools/moveconfig.py VIDEO_BMP_RLE8
CONFIG_SPLASH_SCREEN
CONFIG_SPLASH_SCREEN_ALIGN
CONFIG_SPLASHIMAGE_GUARD
CONFIG_SPLASH_SOURCE
CONFIG_ENV_OVERWRITE
[trini: Rerun migration, remove some comments]
CONFIG_MXC_UART
Acked-by: Peng Fan <peng.fan@nxp.com>
Select default U-Boot and SPL text base for the MX7 SoC. The U-Boot
text base is picked as the one used by various MX7 boards. The SPL
text base however is different.
The SPL text base is set to 0x912000 instead of the usual 0x911000,
that is because the 0x911000 value cannot work. Using 0x911000 as a
SPL text base will result in the DCD header being placed below the
0x911000 address, which is a reserved SRAM area which must not be
used. This will actually trigger eMMC boot failure on MX7D at least.
Hence the increment.
Update all boards affected by this SPL problem to the new SPL_TEXT_BASE.
Cc: Fabio Estevam <festevam@gmail.com>
Cc: NXP i.MX U-Boot Team <uboot-imx@nxp.com>
Cc: Peng Fan <peng.fan@nxp.com>
This partially reverts changes by commit 2cc393f32fd9
("video: make BPP and ANSI configs optional") since it
caused issues with other boards (missing LCD console
output on pinebook, x86 platform or sandbox). Enable
all disabled options again and opt out of not supported
color depth in board defconfigs.
Reported-by: Vagrant Cascadian <vagrant@debian.org>
Signed-off-by: Joris Offouga <offougajoris@gmail.com>
Reviewed-by: Stefano Babic <sbabic@denx.de>
Many boards do not use all selected framebuffer depth
configurations, for such boards there is some unused
code in video and console uclass routines. Make depth
specific code optional to avoid dead code and slightly
reduce binary size. Also make ANSI code optional for
the same reason. When i.e. using only VIDEO_BPP16 the
code size shrinks (below values when using gcc-7.3.0):
$ ./tools/buildman/buildman -b video-wip -sS wandboard
01: Merge git://git.denx.de/u-boot-sh
02: video: add guards around 16bpp/32bbp code
03: video: make BPP and ANSI configs optional
arm: (for 1/1 boards) all -776.0 bss -8.0 text -768.0
Tested-by: Eugen Hristev <eugen.hristev@microchip.com>
Tested-by: Patrice Chotard <patrice.chotard@st.com>
Tested-by: Steffen Dirkwinkel <s.dirkwinkel@beckhoff.com>
Like in Linux, just use CONFIG_MTD to compile the MTD stack.
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
Reviewed-by: Otavio Salvador <otavio@ossystems.com.br>
This commit convert all pico-imx7d to DM_VIDEO
Update pico-hobbit-imx7d_defconfig using pico-imx7d_defconfig as base
to fix device tree file generation. With this all pico-imx7d are
creating u-boot-dtb.img files.
Signed-off-by: Fabio Berton <fabio.berton@ossystems.com.br>
CONFIG_FSL_USDHC
[trini: Add IMX8M, TARGET_S32V234EVB to FSL_USDHC list]
This patch enable usb support with device-tree
Reviewed-by: Jun Nie <jun.nie@linaro.org>
Converted to use fsl_esdhc_imx for i.MX platforms.
Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com>
Reviewed-by: Peng Fan <peng.fan@nxp.com>
Reviewed-by: Lukasz Majewski <lukma@denx.de>
Reviewed-by: Martyn Welch <martyn.welch@collabora.com>
Acked-by: Jason Liu <Jason.hui.liu@nxp.com>
CONFIG_SUPPORT_EMMC_BOOT
As requested by Michal Simek <michal.simek@xilinx.com>, these boards
have no eMMC so CONFIG_SUPPORT_EMMC_BOOT has not been migrated:
xilinx_zynqmp_zc1275_revB
xilinx_zynqmp_zc1751_xm018_dc4
xilinx_zynqmp_zc1751_xm019_dc5
xilinx_zynqmp_zcu100_revC
xilinx_zynqmp_zcu102_rev1_0
xilinx_zynqmp_zcu102_revA
xilinx_zynqmp_zcu102_revB
xilinx_zynqmp_zcu104_revA
xilinx_zynqmp_zcu104_revC
xilinx_zynqmp_zcu106_revA
xilinx_zynqmp_zcu111_revA
Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
Acked-by: Lukasz Majewski <lukma@denx.de>
Acked-by: Patrick Delaunay <patrick.delaunay@st.com>
Acked-by: Ramon Fried <ramon.fried@gmail.com>
Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Tested-by: Sébastien Szymanski <sebastien.szymanski@armadeus.com>
Porting to DM and i.MX8
- warp7 to DM
- kp_imx53 to DM
- Warnings in DT
- MX8QM support
- colibri-imx6ull to DM
- imx7d-pico to DM
- ocotp for MX8
Moved CONFIG_SPL_TEXT_BASE to common/spl/Kconfig and migrate existing
values.
Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
[trini: Re-run migration]
This patch enable convert DM MMC for imx7d-pico board and variant.
Before the DM conversion only usdhc3 was enabled and therefore it appeared
as MMC 0 to u-boot. After enabling MMC DM though usdhc3 defaults to MMC 2,
which left unattended would drive changes to existing pico-pi bootscripts and
environment variables that rely on mmc 0.
Setup the alias of mmc0 and usdhc3 so that existing pico-imx7d boot code will
work unmodified.
When converting to DM_MMC it is necessary that SPL initializes eMMC
by itself, so move the original eMMC initialization from U-Boot
proper to SPL.
Signed-off-by: Fabio Estevam <festevam@gmail.com>
This patch is necessary for convert this board to dm driver model
DM GPIO requires gpio_request() to be called explicitly before
doing any gpio operation
This patch adds DT file hooks for Pico i.MX7D SOM and variant boards
Add support for the VXT VL050-8048NT-C01 panel connected through
the 24 bit parallel LCDIF interface.
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
The bounce buffer is used by a few drivers (most of the MMC drivers)
to overcome limitations in their respective DMA implementation.
This moves the configuration to Kconfig and makes it user-selectable
(even though it will be a required feature to make those drivers
work): the expected usage is for drivers depending on this to 'select'
it unconditionally from their respective Kconfig (see follow-up
patches).
This commit includes a full migration using moveconfig.py to ensure
that each commit compiles. To ensure bisectability we update
dependencies of various drivers to now select BOUNCE_BUFFER when needed.
[trini: Squash all patches to ensure bisectability]
Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Reviewed-by: Otavio Salvador <otavio@ossystems.com.br> [dw_mmc portion]
Reviewed-by: Fabio Estevam <festevam@gmail.com> [mxsmmc portion]
Reviewed-by: Simon Glass <sjg@chromium.org> [tegra portion]
The SPL option for USB gadget should be named after the option for u-boot
(CONFIG_USB_GADGET)
Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
Currently SPL binary is larger than 64kB, which is larger than
CONFIG_SPL_MAX_SIZE defined in imx7_spl.h.
This causes boot failure on the pico-mx7 targets.
Remove CONFIG_SPL_LIBDISK_SUPPORT option for now, so that the SPL
binary can fit into the 64kB range.
This adds a new defconfig which pre-selects the PICO-Hobbit baseboard
allowing a completely non-interactive boot process.
