path: root/configs/pico-dwarf-imx6ul_defconfig
2020-07-28Convert CONFIG_ENV_OVERWRITE to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_ENV_OVERWRITE Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Rerun migration, remove some comments] Signed-off-by: Tom Rini <trini@konsulko.com>
2020-07-28configs: Resync with savedefconfigTom Rini
2020-07-17Convert CONFIG_MXC_UART to KconfigTom Rini
This converts the following to Kconfig: CONFIG_MXC_UART Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Peng Fan <peng.fan@nxp.com>
2020-05-08treewide: mem: Move mtest related defines to KconfigAshok Reddy Soma
Move below defines which are used by mtest utility to Kconfig. CONFIG_SYS_MEMTEST_START CONFIG_SYS_MEMTEST_END Signed-off-by: Ashok Reddy Soma <ashok.reddy.soma@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> [trini: Fix kmcoge5ne board, re-run migration as well] Signed-off-by: Tom Rini <trini@konsulko.com>
2020-04-28configs: Resync with savedefconfigTom Rini
2020-01-22configs: Resync with savedefconfigTom Rini
2019-12-04configs: Resync with savedefconfigTom Rini
2019-11-07configs: Resync with savedefconfigTom Rini
2019-10-08pico: Convert to CONFIG_FSL_USDHCFabio Estevam
The eSDHC config symbol has been converted to CONFIG_FSL_USDHC, so adjust it accordingly in order to fix the build errors: https://travis-ci.org/sbabic/u-boot-imx/jobs/584781580#L1287 Reported-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Fabio Estevam <festevam@gmail.com>
2019-10-08pico-imx6ul: Add LCD supportFabio Estevam
Add support for the VXT VL050-8048NT-C01 panel connected through the 24 bit parallel LCDIF interface. Signed-off-by: Fabio Estevam <festevam@gmail.com> Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2019-10-08pico-imx6ul: Add DWARF baseboard supportOtavio Salvador
This add the boot menu option for the DWARF baseboard as well as a specific config file for users which wish to use it as a pre-defined board. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
