CONFIG_SPL_TEXT_BASE is moved to common/spl/Kconfig, update
pcl063_ull defconfig.
Signed-off-by: Parthiban Nallathambi <pn@denx.de>
CONFIG_FSL_USDHC
[trini: Add IMX8M, TARGET_S32V234EVB to FSL_USDHC list]
Converted to use fsl_esdhc_imx for i.MX platforms.
Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com>
Tested-by: Steffen Dirkwinkel <s.dirkwinkel@beckhoff.com>
Reviewed-by: Peng Fan <peng.fan@nxp.com>
Reviewed-by: Lukasz Majewski <lukma@denx.de>
Reviewed-by: Martyn Welch <martyn.welch@collabora.com>
Acked-by: Jason Liu <Jason.hui.liu@nxp.com>
Extend PHYTEC phyBOARD-i.MX6UL for phyCORE-i.MX6UL SoM (PCL063)
with eMMC on SoM.
CPU: Freescale i.MX6ULL rev1.0 792 MHz (running at 396 MHz)
CPU: Industrial temperature grade (-40C to 105C) at 38C
Reset cause: POR
Model: Phytec phyBOARD-i.MX6ULL-Segin SBC
Board: PHYTEC phyCORE-i.MX6ULL
DRAM: 256 MiB
MMC: FSL_SDHC: 0, FSL_SDHC: 1
In: serial@02020000
Out: serial@02020000
Err: serial@02020000
Net: FEC0
Working:
- Eth0
- i2C
- MMC/SD
- eMMC
- UART (1 & 5)
- USB (host & otg)
Signed-off-by: Parthiban Nallathambi <parthitce@gmail.com>
