path: root/configs/phycore-rk3288_defconfig
2018-07-21rockchip: utilize CONFIG_DEFAULT_FDT_FILEKlaus Goger
Currently the fdtfile environment variable is set to CONFIG_DEFAULT_DEVICE_TREE which is іnternally used as U-Boot devicetree source. The OS can use a different filename and Kconfig gives us the ability to select a default devicetree via CONFIG_DEFAULT_FDT_FILE. This also gives user configuring U-Boot via menuconfig the behaviour someone would expect. Signed-off-by: Klaus Goger <klaus.goger@theobroma-systems.com> Tested-By: Vagrant Cascadian <vagrant@debian.org> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2018-05-30usb: fastboot: Convert USB f_fastboot to shared fastbootAlex Kiernan
Convert USB fastboot code to use shared fastboot protocol. Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-04-25rockchip: defconfig: remove CONFIG_SYS_NS16550Kever Yang
We have enable NS16550 in Kconfig, do not need enable at defconfig Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2018-04-16part: Disable CONFIG_SPL_ISO_PARTITION by defaultAlexander Graf
We enabled CONFIG_ISO_PARTITION by default for distro boot, so that U-Boot could load distro images that usually get shipped as iso images. These images usually come with a board agnostic boot environment. However, there is very little point in having ISO support enabled (for anyone really) in SPL, as the whole idea of SPL is to load U-Boot proper which again is board specific. So the fact that we enable ISO support in U-Boot proper does not mean at all that we want ISO support in U-Boot SPL. Hence, let's remove the Kconfig dependency. Along the way, let's also clean up all those default configs that disabled SPL ISO support. Signed-off-by: Alexander Graf <agraf@suse.de>
2018-04-08treewide: Migrate CONFIG_DISPLAY_BOARDINFO_LATE to KconfigMario Six
Migrate the CONFIG_DISPLAY_BOARDINFO_LATE option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc> [trini: Re-run migration] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-10configs: Resync with savedefconfigTom Rini
2018-02-02Kconfig: usb: rockchip: Remove not needed *_defconfig USB/gadget entriesLukasz Majewski
After moving some USB gadget configs (USB_FUNCTIONS_*) to Kconfig it turned out that following *_defconfig entries for RockChip are not needed. Signed-off-by: Lukasz Majewski <lukma@denx.de>
2018-02-02Kconfig: gadget: Move CONFIG_USB_FUNCTION_MASS_STORAGE to KconfigLukasz Majewski
This commit moves USB_FUNCTION_MASS_STORAGE config to Kconfig. Signed-off-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
2018-01-22Convert CONFIG_ROCKCHIP_USB2_PHY to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_ROCKCHIP_USB2_PHY Signed-off-by: Adam Ford <aford173@gmail.com>
2018-01-10rockchip: rk3288: enable rockusb support on rk3288 based deviceEddie Cai
this patch enable rockusb support on rk3288 based device. Signed-off-by: Eddie Cai <eddie.cai.linux@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-10-03cmd: fastboot: Rework fastboot dependencyMaxime Ripard
Fastboot need a bunch of options to be operating properly, such as the g_dnl gadget, the fastboot command, and some options that make sense. Since fastboot is now part of Kconfig, make sure we have them right. That will also reduce the boilerplate in the defconfigs. Reviewed-by: Łukasz Majewski <lukma@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-10-03usb: gadget: Make g_dnl USB settings commonMaxime Ripard
The g_dnl USB settings for the vendor ID, product ID and manufacturer are actually common settings that can and should be shared by all the gadgets. Make them common by renaming them, and convert all the users. Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Lukasz Majewski <lukma@denx.de> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-09-08usb: net: migrate USB Ethernet adapters to KconfigChris Packham
This migrates ASIX, ASIX88179, MCS7830, RTL8152 and SMSC95XX to Kconfig. Update defconfigs. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-08usb: net: migrate CONFIG_USB_HOST_ETHER to KconfigChris Packham
CONFIG_USB_HOST_ETHER is the framework that the drivers are dependent on USB_HOST_ETHER. Use this as a menu and move the existing LAN75XX and LAN78XX options under new menu. Finally update the defconfigs that need CONFIG_USB_HOST_ETHER. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-05rockchip: phycore: Read configuration EEPROM & set ethaddr in late initWadim Egorov
Read SoM information from EEPROM and set ethaddr in late init. Signed-off-by: Wadim Egorov <w.egorov@phytec.de> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-09-01Kconfig: Migrate all of cmd/fastboot/Kconfig to defconfigsTom Rini
- Move ANDROID_IMAGE_SUPPORT to top level Kconfig under images as it's not strictly part of fastboot. - Add some defaults for the fastboot buffer location and size - Migrate all options listed in cmd/fastboot/Kconfig - Cleanup the README Signed-off-by: Tom Rini <trini@konsulko.com>
2017-09-01configs: Migrate all of the existing USB symbols, except fastbootTom Rini
This syncs all of the currently Kconfig'd symbols out of the headers and into the defconfig files. This has two exceptions, first am335x_evm needs to be converted to DM in SPL and then it can stop undef'ing CONFIG_DM_USB. Leaving this as-is results in a build failure, and without work, run time failure. The other case is am43xx_evm.h and in turn am43xx_evm_usbhost_boot. The problem here is that we need DWC3 USB host mode in SPL, but still desire to have gadget mode in U-Boot proper. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-13rockchip: back-to-bootrom: split BACK_TO_BOOTROM for TPL/SPLPhilipp Tomsich
The back-to-bootrom option is rather unfortunately named CONFIG_ROCKCHIP_SPL_BACK_TO_BOOTROM instead of CONFIG_SPL_ROCKCHIP_BACK_TO_BOOTROM To make is selectable through CONFIG_IS_ENABLED(ROCKCHIP_BACK_TO_BOOTROM), we need to rename it. At the same time, we introduce a TPL_ variant of the option to give us finer-grained control over when it should be used. This change is motivated by our RK3368 boot process, which returns to the boot ROM only from the TPL stage, but not from the SPL stage. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> [added fix-up for evb-rk3229_defconfig and phycore-rk3288_defconfig:] [fixed inverted CONFIG_IS_ENABLED test for rk3288:] Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> include/configs/rock.h: undef
2017-07-11rockchip: Add basic support for phyCORE-RK3288 SoM based carrier boardWadim Egorov
The phyCORE-RK3288 is a SoM (System on Module) containing a RK3288 SoC. The module can be connected to different carrier boards. It can be also equipped with different RAM, SPI flash and eMMC variants. The Rapid Development Kit option is using the following setup: - 1 GB DDR3 RAM (2 Banks) - 1x 4 KB EEPROM - DP83867 Gigabit Ethernet PHY - 16 MB SPI Flash - 4 GB eMMC Flash Add basic support for the PCM-947 carrier board, a RK3288 based development board made by PHYTEC. This board works in a combination with the phyCORE-RK3288 System on Module. Signed-off-by: Wadim Egorov <w.egorov@phytec.de> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
