CONFIG_POWER_FSL
CONFIG_POWER_FSL_MC13892
CONFIG_POWER_HI6553
CONFIG_POWER_LTC3676
CONFIG_POWER_PFUZE100
CONFIG_POWER_PFUZE3000
CONFIG_POWER_SPI
CONFIG_POWER_TPS65090_EC
CONFIG_POWER_TPS65218
CONFIG_POWER_TPS65910
CONFIG_SYS_SPL_MALLOC_SIZE
CONFIG_SYS_SPL_MALLOC_START
We introduce a default value here as well, and CONFIG_SYS_SPL_MALLOC to
control if we have a malloc pool or not.
- Make all users of CUSTOM_SYS_INIT_SP_ADDR reference SYS_INIT_SP_ADDR
- Introduce HAS_CUSTOM_SYS_INIT_SP_ADDR to allow for setting the stack
pointer directly, otherwise we use the common calculation.
- On some platforms that were using the standard calculation but did not
set CONFIG_SYS_INIT_RAM_SIZE / CONFIG_SYS_INIT_RAM_ADDR, set them.
- On a small number of platforms that were not subtracting
GENERATED_GBL_DATA_SIZE do so now via the standard calculation.
- CONFIG_SYS_INIT_SP_OFFSET is now widely unused, so remove it from most
board config header files.
CONFIG_SYS_MAXARGS
Resync all defconfig files using moveconfig.py
CONFIG_NET_RETRY_COUNT
Cc: Ramon Fried <rfried.dev@gmail.com>
CONFIG_USE_BOOTCOMMAND
CONFIG_BOOTCOMMAND
CONFIG_RAMBOOTCOMMAND
CONFIG_NFSBOOTCOMMAND
CONFIG_SYS_NAND_ONFI_DETECTION
CONFIG_SYS_NAND_PAGE_COUNT
CONFIG_SPL_NAND_LOAD
CONFIG_SYS_NAND_BLOCK_SIZE
CONFIG_SYS_NAND_PAGE_SIZE
CONFIG_SYS_NAND_OOBSIZE
Rename these options so that CONFIG_IS_ENABLED can be used with them.
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
[trini: Fixup some incorrect renames]
Rename this option so that CONFIG_IS_ENABLED can be used with it.
CONFIG_BOOTP_SEND_HOSTNAME
CONFIG_SPL_NAND_BASE
CONFIG_SPL_NAND_IDENT
CONFIG_SPL_NAND_DRIVERS
CONFIG_SPL_NAND_ECC
CONFIG_SPL_NAND_SIMPLE
CONFIG_ENV_OVERWRITE
[trini: Rerun migration, remove some comments]
CONFIG_BOOTP_DNS2
CONFIG_BOOTP_PXE_CLIENTARCH
MTD must be enabled when there is a SPI NOR flash using the
SPI_FLASH_MTD config entry.
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
Both symbols must be enabled when there is a raw NAND driver
selected. Also enable them when CONFIG_CMD_NAND is selected to avoid
breaking things when we'll further rework the MTD dependency
description.
[trini: Rebase and migrate a few more boards here]
CONFIG_MTD must be reserved for the MTD core. Like any other
subsystem, prefix the symbol by DM when it comes to DM support.
[trini: Add Kconfig files]
Add more clarity by changing the Kconfig entry name.
[trini: Re-run migration, update a few more cases]
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
CONFIG_ARCH_CPU_INIT
Acked-by: Chris Packham <chris.packham@alliedtelesis.co.nz>
Tested-by: Felix Brack <fb@ltec.ch>
Support for Phytech phyCORE AM335x R2 SOM (PCL060) on the Phytec
phyBOARD-Wega AM335x.
CPU : AM335X-GP rev 2.1
Model: Phytec AM335x phyBOARD-WEGA
DRAM: 256 MiB
NAND: 256 MiB
MMC: OMAP SD/MMC: 0
eth0: ethernet@4a100000
Working:
- Eth0
- i2C
- MMC/SD
- NAND
- UART
- USB (host)
Device trees were taken from Linux mainline:
commit 37624b58542f ("Linux 5.1-rc7")
Signed-off-by: Niel Fourie <lusus@denx.de>
Signed-off-by: Parthiban Nallathambi <pn@denx.de>
Tested-by: Marek Vasut <marex@denx.de>
