This patch moves the following config options to Kconfig:
CONFIG_AUTOBOOT_KEYED
CONFIG_AUTOBOOT_PROMPT
CONFIG_AUTOBOOT_DELAY_STR
CONFIG_AUTOBOOT_STOP_STR
AUTOBOOT_KEYED_CTRLC
[trini: Drop ip04 and pm9263 configs/ additions, those boards previously
set CONFIG_AUTOBOOT_PROMPT but never used it, re-run savedefconfig over
all boards that did change. Make digsy_mtc_* string include seconds to
match others and not warn. ]
Since commit 92ac52082140 (net: Remove all references to
CONFIG_ETHADDR and friends), the ethernet device on UniPhier boards
is not working because of the incorrect (all-zero) MAC address.
Enable CONFIG_NET_RANDOM_ETHADDR to generate the random one.
One disadvantage of commit a26cd04920dc (arch: Make board selection
choices optional) is that Kconfig could create such an insane
.config file that no board is selected.
As PH1-Pro4 is the main stream of UniPhier SoC family, rip off the
"optional" again in favor of PH1-Pro4 as the default SoC.
All the UniPhier boards have switch to Driver Model.
"select DM" is better than default value in each defconfig.
Enable CONFIG_SPL_DM and CONFIG_SPL_SERIAL_SUPPORT, which provide
Driver Model UART support on SPL.
CONFIG_SYS_SPL_MALLOC_{START,SIZE} should be dropped because simple
malloc is preferred on SPL. Dlmalloc requires some static variables
on .data section that is not available yet for NOR boot mode etc.
The 3CS support card (CONFIG_DCC_MICRO_SUPPORT_CARD) used to be used
very often before, but it is recently getting a minority. Swith to
the 1CS support card (CONFIG_PFC_MICRO_SUPPORT_CARD).
PH1-Pro4 includes both EHCI and xHCI IP cores.
Unfortunately, U-Boot cannot enable EHCI and xHCI support
simultaneously. Some users may wish Super-Speed connection.
Disable CONFIG_USB_EHCI_HCD and enable CONFIG_USB_XHCI_HCD.
When Kconfig for U-boot was examined, one of the biggest issues was
how to support multiple images (Normal, SPL, TPL). There were
actually two options, "single .config" and "multiple .config".
After some discussions and thought experiments, I chose the latter,
i.e. to create ".config", "spl/.config", "tpl/.config" for Normal,
SPL, TPL, respectively.
It is true that the "multiple .config" strategy provided us the
maximum flexibility and helped to avoid duplicating CONFIGs among
Normal, SPL, TPL, but I have noticed some fatal problems:
[1] It is impossible to share CONFIG options across the images.
If you change the configuration of Main image, you often have to
adjust some SPL configurations correspondingly. Currently, we
cannot handle the dependencies between them. It means one of the
biggest advantages of Kconfig is lost.
[2] It is too painful to change both ".config" and "spl/.config".
Sunxi guys started to work around this problem by creating a new
configuration target. Commit cbdd9a9737cc (sunxi: kconfig: Add
%_felconfig rule to enable FEL build of sunxi platforms.) added
"make *_felconfig" to enable CONFIG_SPL_FEL on both images.
Changing the configuration of multiple images in one command is a
generic demand. The current implementation cannot propose any
good solution about this.
[3] Kconfig files are getting ugly and difficult to understand.
Commit b724bd7d6349 (dm: Kconfig: Move CONFIG_SYS_MALLOC_F_LEN to
Kconfig) has sprinkled "if !SPL_BUILD" over the Kconfig files.
[4] The build system got more complicated than it should be.
To adjust Linux-originated Kconfig to U-Boot, the helper script
"scripts/multiconfig.sh" was introduced. Writing a complicated
text processor is a shell script sometimes caused problems.
Now I believe the "single .config" will serve us better. With it,
all the problems above would go away. Instead, we will have to add
some CONFIG_SPL_* (and CONFIG_TPL_*) options such as CONFIG_SPL_DM,
but we will not have much. Anyway, this is what we do now in
scripts/Makefile.spl.
I admit my mistake with my apology and this commit switches to the
single .config configuration.
It is not so difficult to do that:
- Remove unnecessary processings from scripts/multiconfig.sh
This file will remain for a while to support the current defconfig
format. It will be removed after more cleanups are done.
- Adjust some makefiles and Kconfigs
- Add some entries to include/config_uncmd_spl.h and the new file
scripts/Makefile.uncmd_spl. Some CONFIG options that are not
supported on SPL must be disabled because one .config is shared
between SPL and U-Boot proper going forward. I know this is not
a beautiful solution and I think we can do better, but let's see
how much we will have to describe them.
- update doc/README.kconfig
More cleaning up patches will follow this.
Now UniPhier platform is only supported with SPL.
There are two kinds of expansion boards which are often used for
the UniPhier platform and they are only exclusively selectable.
It can be better described by the "choice" menu of Kconfig.
FAT-formated USB storage device access is available.
This commit converts UniPhier on-chip serial driver to driver model.
Since UniPhier SoCs do not have Device Tree support, some board files
should be added under arch/arm/cpu/armv7/uniphier/ph1-*/ directories.
(Device Tree support for UniPhier platform is still under way.)
Now the base address and master clock frequency are passed from
platform data, so CONFIG_SYS_UNIPHIER_SERIAL_BASE* and
CONFIG_SYS_UNIPHIER_UART_CLK should be removed.
Tested on UniPhier PH1-LD4 ref board.
This commit allows to build Panasonic UniPhier family:
PH1-LD4, PH1-Pro4, PH1-sLD8
