Set CONFIG_COUNTER_FREQUENCY according to COUNTER_FREQUENCY in
config header file.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
[trini: Re-run migration]
CONFIG_ETHPRIME
This is also done by adding a gating Kconfig option, CONFIG_USE_ETHPRIME
similar to other options that are not always set and control environment
variables.
CONFIG_ARMV7_SECURE_BASE
CONFIG_ARMV7_SECURE_MAX_SIZE
CONFIG_ARMV7_SECURE_RESERVE_SIZE
This hook can be implmented using events, for the three boards that
actually use it.
Add the event type and event handlers. Drop CONFIG_MISC_INIT_F since we
can just use CONFIG_EVENT to control this. Since sandbox always enables
CONFIG_EVENT, we can drop the defconfig lines there too.
CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS
CONFIG_BOOTP_MAY_FAIL
CONFIG_BOOTP_VENDOREX
CONFIG_BOOTP_BOOTFILESIZE
CONFIG_BOOTP_NISDOMAIN
CONFIG_BOOTP_TIMEOFFSET
Cc: Ramon Fried <rfried.dev@gmail.com>
Rsync all defconfig files using moveconfig.py and update
scripts/pylint.base
CONFIG_SCSI_AHCI_PLAT
CONFIG_SYS_SCSI_MAX_SCSI_ID
CONFIG_SYS_SCSI_MAX_LUN
CONFIG_SYS_SATA_MAX_DEVICE
Drop CONFIG_SCSI for everything except the sandbox build. We only need
one build for tests.
This patch adds default defconfig for u-boot update version, the u-boot
update defconfig is a copy of the default (factory) defconfig with:
- adapted text base and environment addresses
- explicit flag that this is a field updated u-boot version
At the time of implementation this version is only used to verify the
update procedure, in future depend on the needs this defconfig can be
extended with additional options.
Signed-off-by: Aleksandar Gerasimovski <aleksandar.gerasimovski@hitachienergy.com>
Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
