path: root/configs/pepper_defconfig
2019-02-01spl: Kconfig: Replace CONFIG_SPL_EXT_SUPPORT to CONFIG_SPL_FS_EXT4Tien Fong Chee
Replace CONFIG_SPL_EXT_SUPPORT to CONFIG_SPLY_FS_EXT4 so both obj-$(CONFIG_$(SPL_)FS_EXT4) and CONFIG_IS_ENABLED(FS_EXT4) can be used to control the build in both SPL and U-Boot. Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-02-01spl: Kconfig: Replace CONFIG_SPL_FAT_SUPPORT with CONFIG_SPL_FS_FATTien Fong Chee
Replace CONFIG_SPL_FAT_SUPPORT with CONFIG_SPL_FS_FAT so obj-$(CONFIG_$(SPL_)FS_FAT) can be used to control the build in both SPL and U-Boot. Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com> Reviewed-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-01-07configs: Resync with savedefconfigTom Rini
2018-11-13configs: Resync with savedefconfigTom Rini
2018-04-13net: phy: Don't limit phy addresses by defaultJoe Hershberger
Some boards expect to find more than one phy while other boards are old and need to be limited to a specific phy address. Only limit the phy address for boards that opt in. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Tested-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Neil Armstrong <narmstrong@baylibre.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2018-04-08Migrate CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG to KconfigAlex Kiernan
Convert CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG to Kconfig Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Petr Vorel <petr.vorel@gmail.com> Reviewed-by: Petr Vorel <petr.vorel at gmail.com>
2018-04-08Migrate CONFIG_DRIVER_TI_CPSW to KconfigAlex Kiernan
This converts CONFIG_DRIVER_TI_CPSW to Kconfig Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-02-23configs: Re-sync with CONFIG_DISTRO_DEFAULTSTom Rini
A number of platforms include config_distro_defaults.h but do not enable CONFIG_DISTRO_DEFAULTS. As they plainly intended to, set that flag and re-sync config files. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-10-20Convert CONFIG_NAND_OMAP_GPMC et al and CONFIG_NAND_MXC to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_NAND_MXC CONFIG_NAND_OMAP_GPMC CONFIG_NAND_OMAP_GPMC_PREFETCH CONFIG_NAND_OMAP_ELM CONFIG_SPL_NAND_AM33XX_BCH CONFIG_SPL_NAND_SIMPLE CONFIG_SYS_NAND_BUSWIDTH_16BIT Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> [trini: Finish migration of CONFIG_SPL_NAND_SIMPLE, fix some build issues, add CONFIG_NAND_MXC so we can do CONFIG_SYS_NAND_BUSWIDTH_16BIT] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-13Convert CONFIG_OMAP3_SPI to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_OMAP3_SPI Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Minor comment tweaks] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-07Move PHY_MICREL and PHY_MICREL_KSZ90X1 to KconfigAlexandru Gagniuc
2017-06-03Kconfig: Migrate FS_FAT / FAT_WRITETom Rini
Now that these symbols are in Kconfig, migrate all users. Use imply on a number of platforms that default to having this enabled. As part of this we must migrate some straglers for CMD_FAT and DOS_PARTITION. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-27ARM: omap2+: rename config to ARCH_OMAP2PLUS and consolidate KconfigMasahiro Yamada
In Linux, CONFIG_ARCH_OMAP2PLUS is used for OMAP2 or later SoCs. Rename CONFIG_ARCH_OMAP2 to CONFIG_ARCH_OMAP2PLUS to follow this naming. Move the OMAP2+ board/SoC choice down to mach-omap2/Kconfig to slim down the arch/arm/Kconfig level. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-01-11mmc: move more driver config options to KconfigMasahiro Yamada
Move (and rename) the following CONFIG options to Kconfig: CONFIG_DAVINCI_MMC (renamed to CONFIG_MMC_DAVINCI) CONFIG_OMAP_HSMMC (renamed to CONFIG_MMC_OMAP_HS) CONFIG_MXC_MMC (renamed to CONFIG_MMC_MXC) CONFIG_MXS_MMC (renamed to CONFIG_MMC_MXS) CONFIG_TEGRA_MMC (renamed to CONFIG_MMC_SDHCI_TEGRA) CONFIG_SUNXI_MMC (renamed to CONFIG_MMC_SUNXI) They are the same option names as used in Linux. This commit was created as follows: [1] Rename the options with the following command: find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \ -type f -print | xargs sed -i -e ' s/CONFIG_DAVINCI_MMC/CONFIG_MMC_DAVINCI/g s/CONFIG_OMAP_HSMMC/CONFIG_MMC_OMAP_HS/g s/CONFIG_MXC_MMC/CONFIG_MMC_MXC/g s/CONFIG_MXS_MMC/CONFIG_MMC_MXS/g s/CONFIG_TEGRA_MMC/CONFIG_MMC_SDHCI_TEGRA/g s/CONFIG_SUNXI_MMC/CONFIG_MMC_SUNXI/g ' [2] Commit the changes [3] Create entries in driver/mmc/Kconfig. (copied from Linux) [4] Move the options with the following command tools/moveconfig.py -y -r HEAD \ MMC_DAVINCI MMC_OMAP_HS MMC_MXC MMC_MXS MMC_SDHCI_TEGRA MMC_SUNXI [5] Sort and align drivers/mmc/Makefile for readability Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Marek Vasut <marex@denx.de>
2016-10-02Kconfig: Separate AM33XX SOC config from target board configAndrew F. Davis
The config option AM33XX is used in several boards and should be defined as a stand-alone option for this SOC. We break this out from target boards that use this SoC and common headers then enable AM33XX on in all the boards that used these targets to eliminate any functional change with this patch. This is similar to what has already been done in 9de852642cae ("arm: Kconfig: Add support for AM43xx SoC specific Kconfig") and is done for the same reasons. Signed-off-by: Andrew F. Davis <afd@ti.com> Acked-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-09-20configs: Re-syncTom Rini
2016-09-16Convert CONFIG_SPL_WATCHDOG_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_POWER_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_LIBDISK_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_FAT_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_EXT_SUPPORT to KconfigSimon Glass
