path: root/configs/peach-pit_defconfig
2016-06-06Merge http://git.denx.de/u-boot-samsungTom Rini
Signed-off-by: Tom Rini <trini@konsulko.com> Conflicts: configs/peach-pi_defconfig configs/peach-pit_defconfig
2016-06-04usb: move CONFIG_USB_XHCI_DWC3 to KconfigMasahiro Yamada
Create an entry for "config USB_XHCI_DWC3" in Kconfig and switch over to it for all boards. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-06-04usb: move CONFIG_USB_XHCI to Kconfig with renamingMasahiro Yamada
Move CONFIG_USB_XHCI to defconfig files for all boards, renaming it into CONFIG_USB_XHCI_HCD. As commented in the help of "config USB_XHCI" entry, this has been a TODO for a long time; now CONFIG_USB_XHCI_HCD and CONFIG_USB_XHCI have been unified in favor of the former. Note: Some boards define CONFIG_USB_XHCI in their headers without CONFIG_USB, which does not meet the "depends on" in Kconfig. I added CONFIG_USB=y for those boards when converting. Otherwise, they would fail to build. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-05-25exynos: video: Convert several boards to driver model for videoSimon Glass
Update several boards to use driver model for video. This involves changes to the EDP and FIMD (frame buffer) drivers. Existing PWM, simple-panel and pwm-backlight drivers are used. These work without additional configuration since they use the device tree settings in the same way as Linux. Boards converted are: - snow - spring - peach-pit - peach-pi All have been tested. Not converted: - MIPI display driver - s5pc210_universal - smdk5420 - smdk5250 - trats - trats2 Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2016-05-25arm: exynos: realign the code to allow support for newer 64-bit platformsThomas Abraham
The existing Exynos 32-bit platform support needs to be realigned in order to support newer 64-bit Exynos platforms. The driver model will be utlized for drivers on the 64-bit Exynos platforms and so some of the older platform support code would not be required for the newer 64-bit Exynos platforms. Cc: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Thomas Abraham <thomas.ab@samsung.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2015-10-23dm: tpm: Move tpm_tis_i2c to tpm_i2c_infineonChristophe Ricard
As there is no TCG specification or recommendation for i2c TPM 1.2, move tpm_tis_i2c driver to tpm_i2c_infineon. Other tpm vendors like Atmel or STMicroelectronics may have a different transport protocol for i2c. Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-08-31tpm: Enable 'tpmtest' command for Chrome OS boards with TPMsSimon Glass
This command provides a few useful tests so enable it for common boards. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Christophe Ricard<christophe-h.ricard@st.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2015-08-31dm: tpm: Convert I2C driver to driver modelSimon Glass
Convert the tpm_tis_i2c driver to use driver model and update boards which use it. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Christophe Ricard<christophe-h.ricard@st.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2015-08-31tpm: Convert board config TPM options to KconfigSimon Glass
Convert all TPM options to Kconfig and tidy up. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Christophe Ricard <christophe-h.ricard@st.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2015-08-21Tidy up some defconfig filesSimon Glass
Several files are out of order. This means that when the moveconfig tool moves CONFIG options to Kconfig it generates a large diff. To avoid this, reorder the files first. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-08-05exynos: Enable new features for exynos5 boardsSimon Glass
Enable PMICs, regulators and the like so that new drivers will be made available. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-08-05dm: cros_ec: Convert the I2C tunnel code to use driver modelSimon Glass
The Chrome OS EC supports tunnelling through to an I2C bus on the EC. This currently uses a copy of the I2C command code and a special 'crosec' sub-command. With driver model we can define an I2C bus which tunnels through to the EC, and use the normal 'i2c' command to access it. This simplifies the code and removes some duplication. Add an I2C driver which tunnels through to the EC. Adjust the EC code to support binding child devices so that it can be set up. Adjust the existing I2C xfer function to fit driver model better. For now the old code remains to allow things to still work. It will be removed in a later patch once the new flow is fully enabled. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-19dm: cros_ec: Convert to KconfigSimon Glass
Since both I2C and SPI are converted to Kconfig, we can convert cros_ec to Kconfig for these buses. LPC will need to wait until driver mode PCI is available. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-09-25kconfig: move CONFIG_DEFAULT_DEVICE_TREE to kconfigMasahiro Yamada
This option specifies the default Device Tree used for the run-time configuration of U-Boot. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@nvidia.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Michal Simek <michal.simek@xilinx.com>
2014-08-30exynos: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the Exynos board select menu to exynos/Kconfig. Consolidate also common settings (CONFIG_SYS_CPU="armv7" and CONFIG_SYS_SOC="exynos"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Minkyu Kang <mk7.kang@samsung.com>
