CONFIG_ENV_IS_IN_SPI_FLASH
Commit bb5930d5c97f ("exynos: video: Convert several boards to driver
model for video") converted the Exynos Chromebooks machines to use DM
for video, but this breaks backward compatibility with the stdout env
var since now stdout is expected to be "vidconsole" instead of "lcd".
This causes display to not work when updating u-boot on these boards
if the old stdout env var is used. Since these are consumer devices,
there's no easy way to have a serial console so users may be confused
thinking that u-boot failed to boot, or in the best case will need to
update the stdout env var blindly to make the display to work again.
There's a CONFIG_VIDCONSOLE_AS_LCD config option to workaround this,
so enable it in the Chromebooks' default configuration files to allow
users to change their stdout env var before the workaround is removed.
Suggested-by: Simon Glass <sjg@chromium.org>
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
This commit was created as follows:
[1] Rename the option with the following command:
find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \
-type f -print | xargs sed -i -e 's/CONFIG_DWMMC/CONFIG_MMC_DW/g'
[2] create the entry for MMC_DW in drivers/mmc/Kconfig
(the prompt and help were copied from Linux)
[3] run "tools/moveconfig.py -y MMC_DW"
[4] add "depends on MMC_DW" to the MMC_DW_ROCKCHIP entry
[5] Clean-up doc/README.socfpga by hand
While I moved the options, I also renamed them so that they are all
prefixed with MMC_SDHCI_.
This commit was created in the following steps.
[1] Rename with the following command
s/CONFIG_MMC_SDMA/CONFIG_MMC_SDHCI_SDMA/g
s/CONFIG_BCM2835_SDHCI/CONFIG_MMC_SDHCI_BCM2835/g
s/CONFIG_KONA_SDHCI/CONFIG_MMC_SDHCI_KONA/g
s/CONFIG_MV_SDHCI/CONFIG_MMC_SDHCI_MV/g
s/CONFIG_S5P_SDHCI/CONFIG_MMC_SDHCI_S5P/g
s/CONFIG_SPEAR_SDHCI/CONFIG_MMC_SDHCI_SPEAR/g
[2] create the Kconfig entries in drivers/mmc/Kconfig
[3] Move the options by the following command
tools/moveconfig.py -y MMC_SDHCI_SDMA MMC_SDHCI_BCM2835 \
MMC_SDHCI_KONA MMC_SDHCI_MV MMC_SDHCI_S5P MMC_SDHCI_SPEAR
[4] Sort drivers/mmc/Makefile for readability
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
Move CONFIG_SDHCI to Kconfig and rename it to CONFIG_MMC_SDHCI.
My motivation for the rename is, ultimately, to make all the MMC
options prefixed with MMC_ and SDHCI options with MMC_SDHCI_,
like Linux.
[1] Rename the config option with the following command:
-type f -print | xargs sed -i -e 's/CONFIG_SDHCI/CONFIG_MMC_SDHCI/g'
[2] create the entry for MMC_SDHCI in drivers/mmc/Kconfig
[3] run "tools/moveconfig.py -y MMC_SDHCI"
[4] add "depends on MMC_SDHCI" to existing SDHCI driver entries
Generated by "tools/moveconfig -s".
This will make config moves easier.
A number of platforms had been using the distro default feature before
it was moved to Kconfig but did not enable the new Kconfig option when
it was enabled. This caused a regression in terms of features and this
introduces breakage when more things move to Kconfig.
CONFIG_SYS_CONSOLE_IS_IN_ENV
CONFIG_CONSOLE_MUX
[trini: Re-order, re-migrate]
CONFIG_LCD
Reviewed-by: Jagan Teki <jteki@openedev.com>
Move these option to Kconfig and tidy up existing uses.
The Power PC boards don't have a suitable common element: the common header
files don't appear to line up with the Kconfig files as far as I can tell.
This results in a lot of defconfig changes.
[trini: Re-migrate, update common/console.c logic]
Move the config IDENT_STRING to Kconfig and migrate all boards
[sivadur: Migrate zynq boards]
Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
[trini: Update configs, add some default to sunxi Kconfig]
Move the SPL settings into common/spl where most of the SPL code is kept.
In some cases we were missing CONFIG_USB=y so enable that when needed.
Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
configs/peach-pi_defconfig
configs/peach-pit_defconfig
Create an entry for "config USB_XHCI_DWC3" in Kconfig and
switch over to it for all boards.
Move CONFIG_USB_XHCI to defconfig files for all boards, renaming it
into CONFIG_USB_XHCI_HCD.
As commented in the help of "config USB_XHCI" entry, this has been
a TODO for a long time; now CONFIG_USB_XHCI_HCD and CONFIG_USB_XHCI
have been unified in favor of the former.
Note:
Some boards define CONFIG_USB_XHCI in their headers without
CONFIG_USB, which does not meet the "depends on" in Kconfig.
I added CONFIG_USB=y for those boards when converting.
Otherwise, they would fail to build.
Update several boards to use driver model for video. This involves changes
to the EDP and FIMD (frame buffer) drivers. Existing PWM, simple-panel and
pwm-backlight drivers are used. These work without additional configuration
since they use the device tree settings in the same way as Linux.
Boards converted are:
- snow
- spring
- peach-pit
- peach-pi
All have been tested. Not converted:
- MIPI display driver
- s5pc210_universal
- smdk5420
- smdk5250
- trats
- trats2
Acked-by: Anatolij Gustschin <agust@denx.de>
The existing Exynos 32-bit platform support needs to be realigned in
order to support newer 64-bit Exynos platforms. The driver model will
be utlized for drivers on the 64-bit Exynos platforms and so some of
the older platform support code would not be required for the newer
Signed-off-by: Thomas Abraham <thomas.ab@samsung.com>
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
There are already two FIT options in Kconfig but the CONFIG options are
still in the header files. We need to do a proper move to fix this.
Move these options to Kconfig and tidy up board configuration:
CONFIG_FIT
CONFIG_OF_BOARD_SETUP
CONFIG_OF_SYSTEM_SETUP
CONFIG_FIT_SIGNATURE
CONFIG_FIT_BEST_MATCH
CONFIG_FIT_VERBOSE
CONFIG_OF_STDOUT_VIA_ALIAS
CONFIG_RSA
Unfortunately the first one is a little complicated. We need to make sure
this option is not enabled in SPL by this change. Also this option is
enabled automatically in the host builds by defining CONFIG_FIT in the
image.h file. To solve this, add a new IMAGE_USE_FIT #define which can
be used in files that are built on the host but must also build for U-Boot
and SPL.
Note: Masahiro's moveconfig.py script is amazing.
[trini: Add microblaze change, various configs/ re-applies]
There are already Kconfig options for SPI flash drivers, but we
have not moved them from config.h to defconfig files. This commit
does this in a batch.
There are already Kconfig options for SPI drivers, but we
commit does this in a batch.
Add CMD_GPIO to Kconfig and run tools/moveconfig.py .
As there is no TCG specification or recommendation for i2c TPM 1.2,
move tpm_tis_i2c driver to tpm_i2c_infineon. Other tpm vendors like Atmel
or STMicroelectronics may have a different transport protocol for i2c.
Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com>
Some boards' defconfigs are disordered. Reorder them.
This command provides a few useful tests so enable it for common boards.
Acked-by: Christophe Ricard<christophe-h.ricard@st.com>
Convert the tpm_tis_i2c driver to use driver model and update boards which
use it.
Convert all TPM options to Kconfig and tidy up.
Acked-by: Christophe Ricard <christophe-h.ricard@st.com>
Several files are out of order. This means that when the moveconfig tool
moves CONFIG options to Kconfig it generates a large diff. To avoid this,
reorder the files first.
Add option to set shell prompt string from menuconfig and migrate
boards globally.
The migration is done as follows:
- Boards that explicitly and unconditionally set CONFIG_SYS_PROMPT had the
entry moved to their defconfig files.
- Boards that defined some kind of #ifdef logic which selects the
CONFIG_SYS_PROMPT (for example qemu-mips) got an #undef CONFIG_SYS_PROMPT
right before the #ifdef logic and were left alone.
- This change forces CONFIG_SYS_PROMPT to be a per board decision, and thus
CONFIG_SYS_PROMPT was removed from all <soc>_common.h and <arch>_common.h
files. This results in a streamlined default value across platforms, and
includes the following files: spear-common, sunxi-common, mv-common,
ti_armv7_common, tegra-common, at91-sama5_common, and zynq-common.
- Boards that relied on <arch/soc>_common.h values of CONFIG_SYS_PROMPT were
not updated in their respective defconfig files under the assumption that
since they did not explicitly define a value, they're fine with whatever
the default is.
- On the other hand, boards that relied on a value defined in some
<boards>_common.h file such as woodburn_common, rpi-common,
bur_am335x_common, ls2085a_common, siemens_am33x_common, and
omap3_evm_common, had their values moved to the respective defconfig files.
- The define V_PROMPT was removed, since it is not used anywhere except for
assigning a value for CONFIG_SYS_PROMPT.
Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
Cc: Igor Grinberg <grinberg@compulab.co.il>
Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
[trini: Add spring, sniper, smartweb to conversion]
Enable PMICs, regulators and the like so that new drivers will be made
available.
The Chrome OS EC supports tunnelling through to an I2C bus on the EC. This
currently uses a copy of the I2C command code and a special 'crosec'
sub-command.
With driver model we can define an I2C bus which tunnels through to the EC,
and use the normal 'i2c' command to access it. This simplifies the code and
removes some duplication.
Add an I2C driver which tunnels through to the EC. Adjust the EC code to
support binding child devices so that it can be set up. Adjust the existing
I2C xfer function to fit driver model better.
For now the old code remains to allow things to still work. It will be
removed in a later patch once the new flow is fully enabled.
them from include/configs.
Some archs/boards specify their own default by pre-defining the config
which causes the Kconfig system to mix up the order of the configs in
the defconfigs... This will cause merge pain if allowed to proliferate.
Remove the configs that behave this way from the archs.
A few configs still remain, but that is because they only exist as
defaults and do not have a proper Kconfig entry. Those appear to be:
SPIFLASH
DISPLAY_BOARDINFO
[trini: rastaban, am43xx_evm_usbhost_boot, am43xx_evm_ethboot updates,
drop DM_USB from MSI_Primo81 as USB_MUSB_SUNXI isn't converted yet to DM]
This also selects CONFIG_NET for any CONFIG_CMD_NET board.
Remove the imx default for CONFIG_NET.
This moves the config that was defined by 60296a8 (commands: add more
command entries in Kconfig).
In order to reduce merge conflicts and to maintain the simplest possible
defconfig files, we should be using the savedefconfig feature of Kconfig
every time a new feature is added. This keeps the defconfig settings to
a minimum (only those things not default) and keeps them in the same
order as the Kconfig options.
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
Since commit e02ee2548afe (kconfig: switch to single .config
configuration), the prefixes in defconfig files such as "+S:",
"+ST:", etc., are meaningless.
This commit was generated by the following command:
find configs -name '*_defconfig' | xargs sed -i 's/^+*S*T*://'
Since both I2C and SPI are converted to Kconfig, we can convert cros_ec
to Kconfig for these buses.
LPC will need to wait until driver mode PCI is available.
This option specifies the default Device Tree used for the run-time
configuration of U-Boot.
Cc: Stephen Warren <swarren@nvidia.com>
Cc: Michal Simek <michal.simek@xilinx.com>
Becuase the board select menu in arch/arm/Kconfig is too big,
move the Exynos board select menu to exynos/Kconfig.
Consolidate also common settings (CONFIG_SYS_CPU="armv7" and
CONFIG_SYS_SOC="exynos").
Acked-by: Minkyu Kang <mk7.kang@samsung.com>
This commit adds:
- arch/${ARCH}/Kconfig
provide a menu to select target boards
- board/${VENDOR}/${BOARD}/Kconfig or board/${BOARD}/Kconfig
set CONFIG macros to the appropriate values for each board
- configs/${TARGET_BOARD}_defconfig
default setting of each board
(This commit was automatically generated by a conversion script
based on boards.cfg)
In Linux Kernel, defconfig files are located under
arch/${ARCH}/configs/ directory.
It works in Linux Kernel since ARCH is always given from the
command line for cross compile.
But in U-Boot, ARCH is not given from the command line.
Which means we cannot know ARCH until the board configuration is done.
That is why all the "*_defconfig" files should be gathered into a
single directory ./configs/.
