path: root/configs/peach-pi_defconfig
2019-05-04Convert CONFIG_SUPPORT_EMMC_BOOT to KconfigAlex Kiernan
This converts the following to Kconfig: CONFIG_SUPPORT_EMMC_BOOT As requested by Michal Simek <michal.simek@xilinx.com>, these boards have no eMMC so CONFIG_SUPPORT_EMMC_BOOT has not been migrated: xilinx_zynqmp_zc1275_revB xilinx_zynqmp_zc1751_xm018_dc4 xilinx_zynqmp_zc1751_xm019_dc5 xilinx_zynqmp_zcu100_revC xilinx_zynqmp_zcu102_rev1_0 xilinx_zynqmp_zcu102_revA xilinx_zynqmp_zcu102_revB xilinx_zynqmp_zcu104_revA xilinx_zynqmp_zcu104_revC xilinx_zynqmp_zcu106_revA xilinx_zynqmp_zcu111_revA Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Acked-by: Lukasz Majewski <lukma@denx.de> Acked-by: Patrick Delaunay <patrick.delaunay@st.com> Acked-by: Ramon Fried <ramon.fried@gmail.com> Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Tested-by: Sébastien Szymanski <sebastien.szymanski@armadeus.com>
2019-03-25Convert CONFIG_ENV_SPI_* to KconfigPatrick Delaunay
This converts the following to Kconfig: CONFIG_ENV_SPI_BUS CONFIG_ENV_SPI_CS CONFIG_ENV_SPI_MAX_HZ CONFIG_ENV_SPI_MODE Most of time these value are not needed, CONFIG_SF_DEFAULT with same value is used, so I introduced CONFIG_USE_ENV_SPI_* to force the associated value for the environment. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2019-01-07configs: Resync with savedefconfigTom Rini
2018-12-13dm: sound: Complete migration to driver modelSimon Glass
All users of sound are converted to use driver model. Drop the old code and the CONFIG_DM_SOUND option. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-12-13dm: exynos: Drop CONFIG_DM_I2C_COMPATSimon Glass
This option is not needed anymore for all exynos boards except arndale. Update the config. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-12-13dm: exynos: sound: Convert to use driver modelSimon Glass
Update snow's device tree and config to use driver model for sound. Also update the others as best we can. Spring does not appear to have audio support in the kernel. The smdk5250 and smdk5420 boards use a wolfson codec which I cannot test with. So the only boards that is tested and known to work are snow, pit and pi. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-10-20net: Add SMC911X driver to Kconfig, convertAdam Ford
We add the various SMC91XX symbols to drivers/net/Kconfig and then this converts the following to Kconfig: CONFIG_SMC911X CONFIG_SMC911X_BASE CONFIG_SMC911X_16_BIT CONFIG_SMC911X_32_BIT Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Apply to the rest of the tree, re-squash old and new patch] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-09-08usb: net: migrate CONFIG_USB_HOST_ETHER to KconfigChris Packham
CONFIG_USB_HOST_ETHER is the framework that the drivers are dependent on USB_HOST_ETHER. Use this as a menu and move the existing LAN75XX and LAN78XX options under new menu. Finally update the defconfigs that need CONFIG_USB_HOST_ETHER. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-01-18Merge git://git.denx.de/u-boot-samsungTom Rini
2017-01-18exynos: video: Enable stdout env var backward compatibility for LCDJavier Martinez Canillas
Commit bb5930d5c97f ("exynos: video: Convert several boards to driver model for video") converted the Exynos Chromebooks machines to use DM for video, but this breaks backward compatibility with the stdout env var since now stdout is expected to be "vidconsole" instead of "lcd". This causes display to not work when updating u-boot on these boards if the old stdout env var is used. Since these are consumer devices, there's no easy way to have a serial console so users may be confused thinking that u-boot failed to boot, or in the best case will need to update the stdout env var blindly to make the display to work again. There's a CONFIG_VIDCONSOLE_AS_LCD config option to workaround this, so enable it in the Chromebooks' default configuration files to allow users to change their stdout env var before the workaround is removed. Suggested-by: Simon Glass <sjg@chromium.org> Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2017-01-11mmc: move CONFIG_DWMMC to Kconfig, renaming to CONFIG_MMC_DWMasahiro Yamada
This commit was created as follows: [1] Rename the option with the following command: find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \ -type f -print | xargs sed -i -e 's/CONFIG_DWMMC/CONFIG_MMC_DW/g' [2] create the entry for MMC_DW in drivers/mmc/Kconfig (the prompt and help were copied from Linux) [3] run "tools/moveconfig.py -y MMC_DW" [4] add "depends on MMC_DW" to the MMC_DW_ROCKCHIP entry [5] Clean-up doc/README.socfpga by hand Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Marek Vasut <marex@denx.de>
2016-12-29mmc: move some SDHCI related options to KconfigMasahiro Yamada
While I moved the options, I also renamed them so that they are all prefixed with MMC_SDHCI_. This commit was created in the following steps. [1] Rename with the following command find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \ -type f -print | xargs sed -i -e ' s/CONFIG_MMC_SDMA/CONFIG_MMC_SDHCI_SDMA/g s/CONFIG_BCM2835_SDHCI/CONFIG_MMC_SDHCI_BCM2835/g s/CONFIG_KONA_SDHCI/CONFIG_MMC_SDHCI_KONA/g s/CONFIG_MV_SDHCI/CONFIG_MMC_SDHCI_MV/g s/CONFIG_S5P_SDHCI/CONFIG_MMC_SDHCI_S5P/g s/CONFIG_SPEAR_SDHCI/CONFIG_MMC_SDHCI_SPEAR/g ' [2] create the Kconfig entries in drivers/mmc/Kconfig [3] Move the options by the following command tools/moveconfig.py -y MMC_SDHCI_SDMA MMC_SDHCI_BCM2835 \ MMC_SDHCI_KONA MMC_SDHCI_MV MMC_SDHCI_S5P MMC_SDHCI_SPEAR [4] Sort drivers/mmc/Makefile for readability Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
2016-12-29mmc: move CONFIG_SDHCI to Kconfig, renaming to CONFIG_MMC_SDHCIMasahiro Yamada
Move CONFIG_SDHCI to Kconfig and rename it to CONFIG_MMC_SDHCI. My motivation for the rename is, ultimately, to make all the MMC options prefixed with MMC_ and SDHCI options with MMC_SDHCI_, like Linux. This commit was created as follows: [1] Rename the config option with the following command: find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \ -type f -print | xargs sed -i -e 's/CONFIG_SDHCI/CONFIG_MMC_SDHCI/g' [2] create the entry for MMC_SDHCI in drivers/mmc/Kconfig [3] run "tools/moveconfig.py -y MMC_SDHCI" [4] add "depends on MMC_SDHCI" to existing SDHCI driver entries Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
2016-12-03Enable DISTRO_DEFAULT on platforms that missed it beforeTom Rini
A number of platforms had been using the distro default feature before it was moved to Kconfig but did not enable the new Kconfig option when it was enabled. This caused a regression in terms of features and this introduces breakage when more things move to Kconfig. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert SILENT_CONSOLE options to KconfigSimon Glass
Move these option to Kconfig and tidy up existing uses. The Power PC boards don't have a suitable common element: the common header files don't appear to line up with the Kconfig files as far as I can tell. This results in a lot of defconfig changes. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagan Teki <jteki@openedev.com> [trini: Re-migrate, update common/console.c logic] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-06-06Merge http://git.denx.de/u-boot-samsungTom Rini
Signed-off-by: Tom Rini <trini@konsulko.com> Conflicts: configs/peach-pi_defconfig configs/peach-pit_defconfig
2016-06-04usb: move CONFIG_USB_XHCI_DWC3 to KconfigMasahiro Yamada
Create an entry for "config USB_XHCI_DWC3" in Kconfig and switch over to it for all boards. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-06-04usb: move CONFIG_USB_XHCI to Kconfig with renamingMasahiro Yamada
Move CONFIG_USB_XHCI to defconfig files for all boards, renaming it into CONFIG_USB_XHCI_HCD. As commented in the help of "config USB_XHCI" entry, this has been a TODO for a long time; now CONFIG_USB_XHCI_HCD and CONFIG_USB_XHCI have been unified in favor of the former. Note: Some boards define CONFIG_USB_XHCI in their headers without CONFIG_USB, which does not meet the "depends on" in Kconfig. I added CONFIG_USB=y for those boards when converting. Otherwise, they would fail to build. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-05-25exynos: video: Convert several boards to driver model for videoSimon Glass
Update several boards to use driver model for video. This involves changes to the EDP and FIMD (frame buffer) drivers. Existing PWM, simple-panel and pwm-backlight drivers are used. These work without additional configuration since they use the device tree settings in the same way as Linux. Boards converted are: - snow - spring - peach-pit - peach-pi All have been tested. Not converted: - MIPI display driver - s5pc210_universal - smdk5420 - smdk5250 - trats - trats2 Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2016-05-25arm: exynos: realign the code to allow support for newer 64-bit platformsThomas Abraham
The existing Exynos 32-bit platform support needs to be realigned in order to support newer 64-bit Exynos platforms. The driver model will be utlized for drivers on the 64-bit Exynos platforms and so some of the older platform support code would not be required for the newer 64-bit Exynos platforms. Cc: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Thomas Abraham <thomas.ab@samsung.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2015-10-23dm: tpm: Move tpm_tis_i2c to tpm_i2c_infineonChristophe Ricard
As there is no TCG specification or recommendation for i2c TPM 1.2, move tpm_tis_i2c driver to tpm_i2c_infineon. Other tpm vendors like Atmel or STMicroelectronics may have a different transport protocol for i2c. Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-08-31tpm: Enable 'tpmtest' command for Chrome OS boards with TPMsSimon Glass
This command provides a few useful tests so enable it for common boards. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Christophe Ricard<christophe-h.ricard@st.com> Reviewed-by: Heiko Schocher <hs@denx.de>
