Move FDT_FIXUP_PARTITIONS to Kconfig and cleanup existing
uses.
move CONFIG_BOOTDELAY into a Kconfig option. Used for this
purpose the moveconfig.py tool in tools.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
There are already two FIT options in Kconfig but the CONFIG options are
still in the header files. We need to do a proper move to fix this.
Move these options to Kconfig and tidy up board configuration:
CONFIG_FIT
CONFIG_OF_BOARD_SETUP
CONFIG_OF_SYSTEM_SETUP
CONFIG_FIT_SIGNATURE
CONFIG_FIT_BEST_MATCH
CONFIG_FIT_VERBOSE
CONFIG_OF_STDOUT_VIA_ALIAS
CONFIG_RSA
Unfortunately the first one is a little complicated. We need to make sure
this option is not enabled in SPL by this change. Also this option is
enabled automatically in the host builds by defining CONFIG_FIT in the
image.h file. To solve this, add a new IMAGE_USE_FIT #define which can
be used in files that are built on the host but must also build for U-Boot
and SPL.
Note: Masahiro's moveconfig.py script is amazing.
[trini: Add microblaze change, various configs/ re-applies]
them from include/configs.
This also selects CONFIG_NET for any CONFIG_CMD_NET board.
Remove the imx default for CONFIG_NET.
This moves the config that was defined by 60296a8 (commands: add more
command entries in Kconfig).
This commit adds:
- arch/${ARCH}/Kconfig
provide a menu to select target boards
- board/${VENDOR}/${BOARD}/Kconfig or board/${BOARD}/Kconfig
set CONFIG macros to the appropriate values for each board
- configs/${TARGET_BOARD}_defconfig
default setting of each board
(This commit was automatically generated by a conversion script
based on boards.cfg)
In Linux Kernel, defconfig files are located under
arch/${ARCH}/configs/ directory.
It works in Linux Kernel since ARCH is always given from the
command line for cross compile.
But in U-Boot, ARCH is not given from the command line.
Which means we cannot know ARCH until the board configuration is done.
That is why all the "*_defconfig" files should be gathered into a
single directory ./configs/.
