path: root/configs/parrot_r16_defconfig
2018-02-02Kconfig: gadget: Move CONFIG_USB_FUNCTION_MASS_STORAGE to KconfigLukasz Majewski
This commit moves USB_FUNCTION_MASS_STORAGE config to Kconfig. Signed-off-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
2017-12-19configs: sunxi: Drop FASTBOOT_FLASHJagan Teki
Now FASTBOOT_FLASH is auto select for sunxi platform, so drop explicit addition. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-10-03sunxi: Remove the MMC index hackMaxime Ripard
The current code, if there's both an eMMC and an MMC slot available on the board, will swap the MMC indices based on whether we booted from the eMMC or the MMC. This way, the MMC we're supposed to boot on will always have the index 0. However, this causes various issues, for example when using other components that base their behaviour on the MMC index, such as fastboot. Let's remove that hack, and take the opposite approach. The MMC will always have the same index, but the bootcmd will pick the same device than the one we booted from. This is done through the introduction of the mmc_bootdev environment variable that will be filled by the board code based on the boot device informations we can get from the SoC. In order to not introduce regressions, we also need to adjust the fastboot MMC device and the environment device in order to set it to the eMMC, over the MMC, like it used to be the case. Tested-by: Chen-Yu Tsai <wens@csie.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-10-03cmd: fastboot: Rework fastboot dependencyMaxime Ripard
Fastboot need a bunch of options to be operating properly, such as the g_dnl gadget, the fastboot command, and some options that make sense. Since fastboot is now part of Kconfig, make sure we have them right. That will also reduce the boilerplate in the defconfigs. Reviewed-by: Łukasz Majewski <lukma@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-10-03sunxi: imply USB_GADGETMaxime Ripard
A good number of our boards have USB_GADGET enabled. Imply it so that all the boards can benefit from it, and remove some boilerplate from our defconfigs. Reviewed-by: Łukasz Majewski <lukma@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-10-03sunxi: provide default USB gadget setupMaxime Ripard
All the Allwinner boards use the same manufacturer, VID and PID for the gadgets. Make them the defaults to remove some boilerplate from our defconfigs. Reviewed-by: Łukasz Majewski <lukma@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-10-03usb: gadget: Make g_dnl USB settings commonMaxime Ripard
The g_dnl USB settings for the vendor ID, product ID and manufacturer are actually common settings that can and should be shared by all the gadgets. Make them common by renaming them, and convert all the users. Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Lukasz Majewski <lukma@denx.de> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-09-01Kconfig: Migrate all of cmd/fastboot/Kconfig to defconfigsTom Rini
- Move ANDROID_IMAGE_SUPPORT to top level Kconfig under images as it's not strictly part of fastboot. - Add some defaults for the fastboot buffer location and size - Migrate all options listed in cmd/fastboot/Kconfig - Cleanup the README Signed-off-by: Tom Rini <trini@konsulko.com>
2017-09-01configs: Migrate all of the existing USB symbols, except fastbootTom Rini
This syncs all of the currently Kconfig'd symbols out of the headers and into the defconfig files. This has two exceptions, first am335x_evm needs to be converted to DM in SPL and then it can stop undef'ing CONFIG_DM_USB. Leaving this as-is results in a build failure, and without work, run time failure. The other case is am43xx_evm.h and in turn am43xx_evm_usbhost_boot. The problem here is that we need DWC3 USB host mode in SPL, but still desire to have gadget mode in U-Boot proper. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-07-02sunxi: Add defconfig and DTS file for Allwinner R16 EVB (Parrot)Quentin Schulz
The Parrot Board is an evaluation board with an Allwinner R16 (assumed to be close to an Allwinner A33), 4GB of eMMC, 512MB of RAM, USB host and OTG, a WiFi/Bluetooth combo chip, a micro SD Card reader, 2 controllable buttons, an LVDS port with separated backlight and capacitive touch panel ports, an audio/microphone jack, a camera CSI port, 2 sets of 22 GPIOs and an accelerometer. The DTS file is identical to the one submitted to the upstream kernel. Signed-off-by: Quentin Schulz <quentin.schulz@free-electrons.com> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
