path: root/configs/p2771-0000-500_defconfig
2019-02-20Kconfig: tegra: Migrate SYS_I2C_TEGRAPeter Robinson
Migrate SYS_I2C_TEGRA from headers to Kconfig Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Cc: Tom Warren <twarren@nvidia.com> Cc: Stephen Warren <swarren@nvidia.com> Cc: Heiko Schocher <hs@denx.de> Cc: Marcel Ziswiler <marcel.ziswiler@toradex.com> Cc: Peter.Chubb@data61.csiro.au Cc: Lucas Stach <dev@lynxeye.de> Cc: Stefan Agner <stefan.agner@toradex.com> Cc: Alban Bedel <alban.bedel@avionic-design.de> Cc: Allen Martin <amartin@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2017-06-01tegra: Convert MMC to use driver model for operationsSimon Glass
Enable CONFIG_DM_MMC_OPS and CONFIG_BLK for all Tegra devices. This moves Tegra to use driver model fully for MMC. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-11-07ARM: tegra: enable Ethernet on p2771-0000Stephen Warren
Enable the Ethernet device in DT, provide board-specific configuration, and enable the driver in Kconfig. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-10-23Convert CONFIG_SYS_STDIO_DEREGISTER to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SYS_STDIO_DEREGISTER This option should never be enabled in SPL, so use CONFIG_IS_ENABLED(SYS_STDIO_DEREGISTER) when checking the option. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Re-sync] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-11dm: mmc: Enable DM_MMC_OPS by default with DM_MMCSimon Glass
These two options go together and it is best to do the conversion in one step. So enable DM_MMC_OPS by default if DM_MMC is enabled. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-11dm: blk: Enable CONFIG_BLK if DM_MMC is enabledSimon Glass
To speed up conversion to CONFIG_BLK, enable it by default when DM_MMC is enabled. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-08-30ARM: tegra: use numeric versioning for p2771-0000Stephen Warren
The board ID EEPROM and board ID stickers on p2771-0000 will use a numeric versioning scheme, with version numbers such as 000/100/200/300/400/500. Within NVIDIA, these versions are also known as A00/A01/A02/A03/A04/B00. However, that numbering scheme is not easily visible outside of NVIDIA, and so does not make much sense to use. Convert U-Boot to use the readily visible numeric scheme. Also, it turns out that the current A02 DT actually applies to board versions 000/100/200 (A00..A02). Consequently rename this to 000 not 200 so that all U-Boot builds are named after the first version of the HW they support. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
