path: root/configs/p201_defconfig
2020-08-10configs: Resync with savedefconfigTom Rini
2020-07-28configs: Resync with savedefconfigTom Rini
2020-06-04configs: Resync with savedefconfigTom Rini
2020-01-22configs: Resync with savedefconfigTom Rini
2019-04-10ARM: meson: display Amlogic SoC InformationJulien Masson
The Amlogic SoCs have a registers containing the die revision and packaging type to determine the SoC family and package marketing name like S905X for the GXL SoC Family. This code is taken from the Linux meson-gx-socinfo driver and adapted to U-Boot printing. Signed-off-by: Julien Masson <jmasson@baylibre.com> Signed-off-by: Neil Armstrong <narmstrong@baylibre.com> [narmstrong: also updated new p200/p201 defconfigs]
2019-04-10ARM: board: meson: add p201 boardMohammad Rasim
This adds support for p201 reference boards Signed-off-by: Mohammad Rasim <mohammad.rasim96@gmail.com> Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
