Commit 08574ed339fb ("Convert CONFIG_SYS_MONITOR_LEN to Kconfig") moved
the definition of said config variable from the common sunxi header to
*every board's* defconfig.
This is a platform choice, not board specific, so remove the variable
from there, instead set the one value for all Allwinner boards in
Kconfig.
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Acked-by: Jernej Skrabec <jernej.skrabec@gmail.com>
To do this, we set a default of 0 for everyone because there are a
number of cases where we define CONFIG_SYS_MONITOR_LEN but the only
impact is that we set TOTAL_MALLOC_LEN to be CONFIG_SYS_MALLOC_LEN +
CONFIG_ENV_SIZE, so we must continue to allow all boards to set this
value. Update the SPL code to use 200 KB as the default raw U-Boot size
directly, if we don't have a real CONFIG_SYS_MONITOR_LEN value.
When some configuration symbols were converted from header files to
Kconfig, their values were placed into *every* defconfig file.
Since we now have sensible per-SoC defaults defined in Kconfig, those
values are now redundant, and can just be removed.
This affects CONFIG_SPL_STACK, CONFIG_SYS_PBSIZE, CONFIG_SPL_MAX_SIZE,
and CONFIG_SYS_BOOTM_LEN.
As part of this, rework error handling in boot/bootm.c so that we pass
the buffer size to handle_decomp_error as CONFIG_SYS_BOOTM_LEN will not
be available to host tools but we do know the size that we passed to
malloc().
Cc: Soeren Moch <smoch@web.de>
CONFIG_SPL_STACK
CONFIG_SYS_PBSIZE
Some sunxi boards ship with SPI flash, which allows booting through the
BootROM. We cover this functionality by a separate SPL "mini" driver.
Separately we have a proper DM_SPI driver for U-Boot proper, which
provides access to the SPI flash through the "sf" command. That allows
to update the firmware on the SPI flash, also to store the environment
there.
However only very few boards actually enable support for U-Boot proper,
even though that would work and the SPL part is configured.
Use the cleaned up configuration scheme to enable SPI flash on those
boards which mention a SPI flash in their .dts, or which use the SPL SPI
support.
Out of the box this would enable storing the environment on the SPI
flash, and allows people to read or write the flash from U-Boot, for
instance to update the SPI flash when booted via an SD card.
For this to actually work there must be a "spi0" alias in the DT, which
most boards are missing. But this should be addressed separately.
Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
Commit 7945caf22c44 ("arm: sunxi: Enable SPI/SPI-FLASH support for A64")
selected CONFIG_SPI by default on all Allwinner A64 boards, even though
only 4 out of the 14 A64 boards have a SPI flash chip. All other SoCs
had to manually select DM_SPI and friends, even though they are a
platform property (the sunxi SPI driver is DM_SPI only).
Clean this up to allow easy selection of SPI flash support in U-Boot
proper, by selecting DM_SPI and DM_SPI_FLASH *if* CONFIG_SPI is
selected, for *all* Allwinner SoCs. This simplifies the defconfig for
two Libretech boards already.
Also remove the forced CONFIG_SPI from the A64 Kconfig, instead let the
four boards which allow SPI booting select this explicitly.
Any board wishing to support SPI flash in U-Boot proper now just defines
CONFIG_SPI and CONFIG_SPI_FLASH_<vendor> in its defconfig, Kconfig takes
care of the rest.
Now that those common Allwinner config symbols are defined automatically
for all boards in their Kconfig files, we can remove the now redundant
definitions from the boards' _defconfig files.
Some boards had a differing definiton for some of those symbols, it
looks like mostly to "merge races" when the symbol was introduced (new
board *_defconfig file missed the "add symbol to all files" patch).
Acked-by: Maxime Ripard <mripard@kernel.org>
Tested-by: Jagan Teki <jagan@amarulasolutions.com> # Amarula A64-Relic
Orange Pi Win has gigabit ethernet port, but default U-Boot
configuration for that board enabled ethernet driver but
didn't enable realtek phy.
Fix that.
Signed-off-by: Jernej Skrabec <jernej.skrabec@siol.net>
For Allwinner SoCs the CONFIG_SYS_SPI_U_BOOT_OFFS value is not really a
board choice: The boot ROM only loads the SPL from offset 0 of the SPI
NOR flash, and loads at most 32KB. This is a similar situation as on MMC,
so consequently we create our "joint" image (SPL + U-Boot proper) with
that 32KB offset during the build.
So define the value of this symbol to be 32KB by default for every
Allwinner SoC. This removes the definition of this symbol from the
_defconfig files, and avoids every board to define this over and over
again.
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
Signed-off-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
[trini: Expose this for SPL_SPI_SUNXI for now]
CONFIG_USE_PREBOOT
CONFIG_PREBOOT
Both are together in one commit, since otherwise the former causes kconfig
to define the latter, which gives duplicate symbol errors.
Includes a manual fixup for CONFIG_PREBOOT in ids8313_defconfig since the
backslash lands in the wrong place. Similarly with socfpga_vining_fpga.
The choice of the SPL_TEXT_BASE is not really a decision that should be
specified by each board's defconfig, as this setting is actually
dictated by the SoC's memory map and the BootROM behaviour.
To make this obvious and reduce the clutter in the defconfig files,
let's specify the SoC constraints in the Kconfig stanza.
This allows us to remove these lines from the defconfig files again.
Acked-by: Maxime Ripard <maxime.ripard@bootlin.com>
Moved CONFIG_SPL_TEXT_BASE to common/spl/Kconfig and migrate existing
values.
Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
[trini: Re-run migration]
Onc of key blocker for using USB Generic host controller
drivers in Allwinner are CLK and RESET drivers, now these
available for USB usage.
So switch sunxi USB use EHCI and OHCI Generic controllers.
Enabling USB is wisely a board choise, So Enable USB_OHCI_HCD
where it already have USB_EHCI_HCD
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
We enabled CONFIG_ISO_PARTITION by default for distro boot, so that U-Boot
could load distro images that usually get shipped as iso images. These images
usually come with a board agnostic boot environment.
However, there is very little point in having ISO support enabled (for anyone
really) in SPL, as the whole idea of SPL is to load U-Boot proper which again
is board specific. So the fact that we enable ISO support in U-Boot proper does
not mean at all that we want ISO support in U-Boot SPL.
Hence, let's remove the Kconfig dependency. Along the way, let's also clean up
all those default configs that disabled SPL ISO support.
Commit 278b90ce786f ("configs: Migrate CONFIG_SYS_TEXT_BASE") made
CONFIG_SYS_TEXT_BASE a proper Kconfig variable, with the consequence
of moving the common definition shared by almost every sunxi board
into 123 individual defconfig files. But the U-Boot start address
for Allwinner boards is a platform decision which has been around for
ages, so defining it in each *board* config file seems a bit over the
top.
Define the standard values (160MB into DRAM for most SoCs, with two
SoC exceptions) if ARCH_SUNXI is selected, and delete the lines from
the individual defconfigs.
Reviewed-by: Jagan Teki <jagan@openedev.com>
On the NIOS2 and Xtensa architectures, we do not have
CONFIG_SYS_TEXT_BASE set. This is a strict migration of the current
values into the defconfig and removing them from the headers.
I did not attempt to add more default values in and for now will leave
that to maintainers.
cmd/Makefile has:
ifdef CONFIG_FPGA
obj-$(CONFIG_CMD_FPGA) += fpga.o
endif
which means that if CONFIG_FPGA is not set, CONFIG_CMD_FPGA silently
does nothing. Let's remove that Makefile conditional and instead express
this equivalent dependency in Kconfig, so a lot of redundant
# CONFIG_CMD_FPGA is not set
can be removed from board defconfigs that don't actually have an FPGA.
Having this as a 'default y' is rather annoying because it doesn't
actually compile unless other options are defined in the board header:
../cmd/bootm.c: In function 'do_imls_nor':
../cmd/bootm.c:330:7: error: 'CONFIG_SYS_MAX_FLASH_BANKS' undeclared (first use in this function); did you mean 'CONFIG_SYS_MAX_FLASH_SECT'?
i < CONFIG_SYS_MAX_FLASH_BANKS; ++i, ++info) {
Make it 'default n' so people who develop new boards that start from a
blank defconfig have one less compilation failure to debug.
This syncs all of the currently Kconfig'd symbols out of the headers and
into the defconfig files. This has two exceptions, first am335x_evm
needs to be converted to DM in SPL and then it can stop undef'ing
CONFIG_DM_USB. Leaving this as-is results in a build failure, and
without work, run time failure. The other case is am43xx_evm.h and in
turn am43xx_evm_usbhost_boot. The problem here is that we need DWC3 USB
host mode in SPL, but still desire to have gadget mode in U-Boot proper.
Orangepi Win/WinPlus is an open-source single-board computer
using the Allwinner A64 SOC.
A64 Orangepi Win/WinPlus has
- A64 Quad-core Cortex-A53 64bit
- 1GB(Win)/2GB(Win Plus) DDR3 SDRAM
- Debug TTL UART
- Four USB 2.0
- HDMI
- LCD
- Audio and MIC
- Wifi + BT
- IR receiver
- 5V DC power supply
