path: root/configs/orangepi_win_defconfig
2017-09-01configs: Migrate all of the existing USB symbols, except fastbootTom Rini
This syncs all of the currently Kconfig'd symbols out of the headers and into the defconfig files. This has two exceptions, first am335x_evm needs to be converted to DM in SPL and then it can stop undef'ing CONFIG_DM_USB. Leaving this as-is results in a build failure, and without work, run time failure. The other case is am43xx_evm.h and in turn am43xx_evm_usbhost_boot. The problem here is that we need DWC3 USB host mode in SPL, but still desire to have gadget mode in U-Boot proper. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-06-14sun50i: a64: Add initial Orangepi Win/WinPlus supportJagan Teki
Orangepi Win/WinPlus is an open-source single-board computer using the Allwinner A64 SOC. A64 Orangepi Win/WinPlus has - A64 Quad-core Cortex-A53 64bit - 1GB(Win)/2GB(Win Plus) DDR3 SDRAM - Debug TTL UART - Four USB 2.0 - HDMI - LCD - Audio and MIC - Wifi + BT - IR receiver - 5V DC power supply Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Tested-by: Jagan Teki <jagan@amarulasolutions.com>
