Some sunxi boards ship with SPI flash, which allows booting through the
BootROM. We cover this functionality by a separate SPL "mini" driver.
Separately we have a proper DM_SPI driver for U-Boot proper, which
provides access to the SPI flash through the "sf" command. That allows
to update the firmware on the SPI flash, also to store the environment
there.
However only very few boards actually enable support for U-Boot proper,
even though that would work and the SPL part is configured.
Use the cleaned up configuration scheme to enable SPI flash on those
boards which mention a SPI flash in their .dts, or which use the SPL SPI
support.
Out of the box this would enable storing the environment on the SPI
flash, and allows people to read or write the flash from U-Boot, for
instance to update the SPI flash when booted via an SD card.
For this to actually work there must be a "spi0" alias in the DT, which
most boards are missing. But this should be addressed separately.
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
Now that those common Allwinner config symbols are defined automatically
for all boards in their Kconfig files, we can remove the now redundant
definitions from the boards' _defconfig files.
Some boards had a differing definiton for some of those symbols, it
looks like mostly to "merge races" when the symbol was introduced (new
board *_defconfig file missed the "add symbol to all files" patch).
Acked-by: Maxime Ripard <mripard@kernel.org>
Tested-by: Jagan Teki <jagan@amarulasolutions.com> # Amarula A64-Relic
For Allwinner SoCs the CONFIG_SYS_SPI_U_BOOT_OFFS value is not really a
board choice: The boot ROM only loads the SPL from offset 0 of the SPI
NOR flash, and loads at most 32KB. This is a similar situation as on MMC,
so consequently we create our "joint" image (SPL + U-Boot proper) with
that 32KB offset during the build.
So define the value of this symbol to be 32KB by default for every
Allwinner SoC. This removes the definition of this symbol from the
_defconfig files, and avoids every board to define this over and over
again.
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
Signed-off-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
[trini: Expose this for SPL_SPI_SUNXI for now]
CONFIG_USE_PREBOOT
CONFIG_PREBOOT
Both are together in one commit, since otherwise the former causes kconfig
to define the latter, which gives duplicate symbol errors.
Includes a manual fixup for CONFIG_PREBOOT in ids8313_defconfig since the
backslash lands in the wrong place. Similarly with socfpga_vining_fpga.
The choice of the SPL_TEXT_BASE is not really a decision that should be
specified by each board's defconfig, as this setting is actually
dictated by the SoC's memory map and the BootROM behaviour.
To make this obvious and reduce the clutter in the defconfig files,
let's specify the SoC constraints in the Kconfig stanza.
This allows us to remove these lines from the defconfig files again.
Acked-by: Maxime Ripard <maxime.ripard@bootlin.com>
Moved CONFIG_SPL_TEXT_BASE to common/spl/Kconfig and migrate existing
values.
Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
[trini: Re-run migration]
Most of the boards we support with H3/H5 enable DRAM on-die termination,
which is consistent with the high DRAM clocks that are used.
Make it the default (like it's done for other similar platforms) instead
of defining it in each defconfig.
Signed-off-by: Paul Kocialkowski <paul.kocialkowski@bootlin.com>
Reviewed-by: Jagan Teki <jagan@openedev.com>
Most H3/H5 boards we support have the DRAM ZQ value set to 3881979,
which is also consistent with the default set for the R40.
Make this value the default on H3/H5 instead of 123.
Onc of key blocker for using USB Generic host controller
drivers in Allwinner are CLK and RESET drivers, now these
available for USB usage.
So switch sunxi USB use EHCI and OHCI Generic controllers.
Enabling USB is wisely a board choise, So Enable USB_OHCI_HCD
where it already have USB_EHCI_HCD
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
Orange Pi R1 is an open-source single-board computer using the
Allwinner H2+ SOC.
H2+ Orange Pi R1 has
- Quad-core Cortex-A7
- 256MB DDR3
- micrSD slot
- 128MBit SPI Nor flash
- Debug TTL UART
- 100MBit/s Ethernet (H2+)
- 100MBit/s Ethernet (RTL8152B)
- Wifi (RTL8189ETV)
- USB 2.0 OTG + power supply
This board is very similar to the Orange Pi Zero.
The device tree file is copied from the Linux kernel 4.17.
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
