path: root/configs/orangepi_pc_plus_defconfig
2017-09-01configs: Migrate all of the existing USB symbols, except fastbootTom Rini
This syncs all of the currently Kconfig'd symbols out of the headers and into the defconfig files. This has two exceptions, first am335x_evm needs to be converted to DM in SPL and then it can stop undef'ing CONFIG_DM_USB. Leaving this as-is results in a build failure, and without work, run time failure. The other case is am43xx_evm.h and in turn am43xx_evm_usbhost_boot. The problem here is that we need DWC3 USB host mode in SPL, but still desire to have gadget mode in U-Boot proper. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-07-31sunxi: Re-enable h3 emac supportHans de Goede
With the recent bug fixes for the sun8i_emac driver all known issues are resolved, so we can re-enable the driver. While at it, also enable the emac on the Orange Pi One. Cc: Chen-Yu Tsai <wens@csie.org> Cc: Corentin LABBE <clabbe.montjoie@gmail.com> Cc: Amit Singh Tomar <amittomer25@gmail.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk> Acked-by: Jagan Teki <jteki@openedev.com>
2016-07-26sunxi: Add defconfig and dts file for the Orange Pi PC Plus SBCHans de Goede
There is a new Orange Pi PC *Plus* version available now, this is an extended version of the regular Orange Pi PC with sdio wifi and an eMMC. The upstream kernel devs have decided that they want a separate dts for the PC Plus rather then sharing a single dts between the regular PC and the PC Plus. So add a new orangepi_pc_plus_defconfig to match. The added dts file matches the one submitted to the upstream kernel. Signed-off-by: Hans de Goede <hdegoede@redhat.com>
