path: root/configs/orangepi_pc_plus_defconfig
2016-07-31sunxi: Re-enable h3 emac supportHans de Goede
With the recent bug fixes for the sun8i_emac driver all known issues are resolved, so we can re-enable the driver. While at it, also enable the emac on the Orange Pi One. Cc: Chen-Yu Tsai <wens@csie.org> Cc: Corentin LABBE <clabbe.montjoie@gmail.com> Cc: Amit Singh Tomar <amittomer25@gmail.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk> Acked-by: Jagan Teki <jteki@openedev.com>
2016-07-26sunxi: Add defconfig and dts file for the Orange Pi PC Plus SBCHans de Goede
There is a new Orange Pi PC *Plus* version available now, this is an extended version of the regular Orange Pi PC with sdio wifi and an eMMC. The upstream kernel devs have decided that they want a separate dts for the PC Plus rather then sharing a single dts between the regular PC and the PC Plus. So add a new orangepi_pc_plus_defconfig to match. The added dts file matches the one submitted to the upstream kernel. Signed-off-by: Hans de Goede <hdegoede@redhat.com>
