With updated moveconfig.py and an better default, re-generate
the migration of BOOTDELAY to the defconfig.
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
move CONFIG_BOOTDELAY into a Kconfig option. Used for this
purpose the moveconfig.py tool in tools.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Recently a set of CONFIG_CMD_FOO defines was moved from being defined
in config_distro_defaults to Kconfig, and added to all sunxi defconfigs
to compensate.
Instead of explictly selecting these in all sunxi defconfigs,
simply always select these for sunxi boards. This makes the defconfigs
simpler and ensures a consistent set of available commands across all
sunxi boards.
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
We have CONFIG_CMD_GPIO=y in almost all sunxi boards, but after
its Kconfig conversion it has ended up missing on some recently
added boards.
Simply select it for ARCH_SUNXI, so that we get it on all
sunxi boards for both a consistent user experience and simpler
defconfig files.
Acked-by: Ian Campbell <ijc@hellion.org.uk>
This fixes the USB ports not working on the orangepi_plus and stops us
from messing with gpio-s which we should not touch on the orangepi_pc.
Add support for phy 1-3.
Signed-off-by: Jelle van der Waa <jelle@vdwaa.nl>
[hdegoede@redhat.com: use setclrbits_le32 instead of read-modify-write]
SY8106A is a PMIC which is used on the Allwinner
H3 Orange Pi Pc and Plus board. The VOUT1_SEL register is
implemented to set the default V-CPU voltage to 1200 mV.
This driver is required to ensure the SY8106A V-CPU
voltage is set to 1200 mV after a software reset. On cold
boot the default SY8106A output voltage is selected to be
1200 mV by a pair of resistors on the Orange Pi PC and Plus.
Tested-by: Siarhei Siamashka <siarhei.siamashka@gmail.com>
Acked-by: Siarhei Siamashka <siarhei.siamashka@gmail.com>
[hdegoede@redhat.com: Minor cleanups]
applied with fixing 2 checkpatch warnings:
WARNING: please, no space before tabs
There are some reports of stability issues at 672 MHz, see:
http://linux-sunxi.org/Orange_Pi_PC#DRAM_clock_speed_limit
So reduce the DRAM speed to 624MHz which seems to be reliable everywhere.
Select SYS_NS16550 from Kconfig instead of setting it in all our
defconfig files.
There are already Kconfig options for SPI drivers, but we
have not moved them from config.h to defconfig files. This
commit does this in a batch.
After introduction of CONFIG_SYS_NS16550 these defconfig files were
added and need to be updated.
Add defconfig files for the Orangepi Plus and Orangepi PC.
