path: root/configs/orangepi_one_defconfig
2016-07-31sunxi: Re-enable h3 emac supportHans de Goede
With the recent bug fixes for the sun8i_emac driver all known issues are resolved, so we can re-enable the driver. While at it, also enable the emac on the Orange Pi One. Cc: Chen-Yu Tsai <wens@csie.org> Cc: Corentin LABBE <clabbe.montjoie@gmail.com> Cc: Amit Singh Tomar <amittomer25@gmail.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk> Acked-by: Jagan Teki <jteki@openedev.com>
2016-05-25sunxi: Enable a bunch of commands by default on sunxiHans de Goede
Recently a set of CONFIG_CMD_FOO defines was moved from being defined in config_distro_defaults to Kconfig, and added to all sunxi defconfigs to compensate. Instead of explictly selecting these in all sunxi defconfigs, simply always select these for sunxi boards. This makes the defconfigs simpler and ensures a consistent set of available commands across all sunxi boards. Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-04-12sunxi: Add defconfig and dts file for Orange Pi One SBCHans de Goede
The Orange Pi One SBC, is a stripped down version of the popular Orange Pi PC. The one is a H3 based SBC, with 512M of RAM, micro-sd slot, 1 host usb, 1 otg usb, hdmi and 100Mbit ethernet. The dts is identical to the dts submitted to the upstream kernel. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
