path: root/configs/orangepi_2_defconfig
2016-09-03sunxi: Enable emac on H3 orangepi boardsHans de Goede
The Orange Pi 2 and Orange Pi Plus also come with ethernet, enable support for this. Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-05-25sunxi: Enable a bunch of commands by default on sunxiHans de Goede
Recently a set of CONFIG_CMD_FOO defines was moved from being defined in config_distro_defaults to Kconfig, and added to all sunxi defconfigs to compensate. Instead of explictly selecting these in all sunxi defconfigs, simply always select these for sunxi boards. This makes the defconfigs simpler and ensures a consistent set of available commands across all sunxi boards. Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-04-12sunxi: Enable CMD_GPIO on all sunxi boardsHans de Goede
We have CONFIG_CMD_GPIO=y in almost all sunxi boards, but after its Kconfig conversion it has ended up missing on some recently added boards. Simply select it for ARCH_SUNXI, so that we get it on all sunxi boards for both a consistent user experience and simpler defconfig files. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2016-03-23sunxi: Add defconfig and dts for Orange Pi 2 SBCHans de Goede
The Orange Pi 2 is a SBC based on the Allwinner H3 SoC with a uSD slot, 4 USB ports connected via a USB-2 hub, a 10/100M ethernet port using the SoC's integrated PHY, Wifi via a RTL8189ETV sdio wifi chip, USB OTG, HDMI, a TRRS headphone jack for stereo out and composite out, a microphone, an IR receiver, a CSI connector, 2 LEDs, a 3 pin UART header and a 40-pin GPIO header. The added dts file is identical to the one submitted to the upstream kernel. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
