path: root/configs/orangepi-rk3399_defconfig
2019-08-23rockchip: rk3399: defconfig: remove SPL raw image supportKever Yang
RK3399 SPL only support FIT image for ATF bl31. Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
2019-08-14configs: Resync with savedefconfigTom Rini
2019-07-20rockchip: rk3399: default enable SPL LIBCOMMON and LIBGENERICKever Yang
We needs SPL LIBCOMMON and LIBGENERIC for all boards, so we can enable them by default and no need to define in each board. Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
2019-07-20rockchip: rk3399: use default value for SYS_MALLOC_F_LENKever Yang
There is no difference in rk3399 board use for SYS_MALLOC_F_LEN, so we can use default value. Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
2019-05-30rk3399: orangepi: Enable TPLJagan Teki
Enable TPL for OrangePI rk3399 board. Reviewed-by: Kever Yang <kever.yang@rock-chips.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2019-05-26configs: Resync with savedefconfigTom Rini
2019-05-08arm: rockchip: rk3399: Move common configs in KconfigJagan Teki
Few SPL and U-Boot proper configs are common to all rk3399 target defconfigs, move them and select it from platform kconfig. Moved configs: - SPL_ATF - SPL_ATF_NO_PLATFORM_PARAM if SPL_ATF - SPL_LOAD_FIT - SPL_CLK if SPL - SPL_PINCTRL if SPL - SPL_RAM if SPL - SPL_REGMAP if SPL - SPL_SYSCON if SPL - CLK - FIT - PINCTRL - RAM - REGMAP - SYSCON - DM_PMIC - DM_REGULATOR_FIXED Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2019-05-08Kconfig: Add default SPL_FIT_GENERATOR for rockchipJagan Teki
Add default SPL_FIT_GENERATOR py script for rockchip platforms if specific target enabled SPL_LOAD_FIT. So, this would help get rid of explicitly mentioning the default SPL FIT generator in defconfigs. however some targets, like puma_rk3399 still require their own FIT generator so in those cases the default will override with defconfig defined generator. Reviewed-by: Paul Kocialkowski <paul.kocialkowski@bootlin.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2019-05-08rockchip: rk3399: orangepi: Add SPL_TEXT_BASEJagan Teki
CONFIG_SPL_TEXT_BASE was available in configs/rk3399_common.h when the OrangePI rk3399 board supported during first version patch. But, later below change which move this config into Kconfig and same has been merged in mainline tree. "configs: move CONFIG_SPL_TEXT_BASE to Kconfig" (sha1: f89d6133eef2e068f9c33853b6584d7fcbfa9d2e) Unfortunately, the maintainer applied the initial version patch, instead of looking for next version changes. Fix it by adding SPL_TEXT_BASE in orangepi-rk3399 defconfig. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2019-05-01rockchip: rk3399: Add Orangepi RK3399 supportJagan Teki
Add initial support for Orangepi RK3399 board. Specification - Rockchip RK3399 - 2GB/4GB DDR3 - 16GB eMMC - SD card slot - RTL8211E 1Gbps - AP6356S WiFI/BT - HDMI In/Out, DP, MIPI DSI/CSI - Mini PCIe - Sensors, Keys etc - DC12V-2A and DC5V-2A Commit details about Linux DTS sync: "arm64: dts: rockchip: Add support for the Orange Pi RK3399" (sha1: d3e71487a790979057c0fdbf32f85033639c16e6) Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
