CONFIG_SPL_NS16550_MIN_FUNCTIONS
CONFIG_SYS_NS16550_MEM32
CONFIG_SYS_NS16550_PORT_MAPPED
CONFIG_SYS_NS16550_REG_SIZE
CONFIG_SYS_NS16550_SERIAL
To do this we also introduce CONFIG_SPL_SYS_NS16550_SERIAL so that
platforms can enable the legacy driver here for SPL.
The current name is inconsistent with SPL which uses CONFIG_SPL_TEXT_BASE
and this makes it imposible to use CONFIG_VAL().
Rename it to resolve this problem.
CONFIG_LBA48
CONFIG_SYS_64BIT_LBA
- Make all users of CUSTOM_SYS_INIT_SP_ADDR reference SYS_INIT_SP_ADDR
- Introduce HAS_CUSTOM_SYS_INIT_SP_ADDR to allow for setting the stack
pointer directly, otherwise we use the common calculation.
- On some platforms that were using the standard calculation but did not
set CONFIG_SYS_INIT_RAM_SIZE / CONFIG_SYS_INIT_RAM_ADDR, set them.
- On a small number of platforms that were not subtracting
GENERATED_GBL_DATA_SIZE do so now via the standard calculation.
- CONFIG_SYS_INIT_SP_OFFSET is now widely unused, so remove it from most
board config header files.
CONFIG_SYS_MAXARGS
CONFIG_BOARD_SIZE_LIMIT
To do this, introduce CONFIG_HAS_BOARD_SIZE_LIMIT.
CONFIG_SYS_FAULT_ECHO_LINK_DOWN
Cc: Ramon Fried <rfried.dev@gmail.com>
CONFIG_RESET_PHY_R
CONFIG_SYS_IDE_MAXBUS
CONFIG_SYS_IDE_MAXDEVICE
CONFIG_SYS_ATA_BASE_ADDR
CONFIG_SYS_ATA_STRIDE
CONFIG_SYS_ATA_DATA_OFFSET
CONFIG_SYS_ATA_REG_OFFSET
CONFIG_SYS_ATA_ALT_OFFSET
CONFIG_SYS_ATA_IDE0_OFFSET
CONFIG_SYS_ATA_IDE1_OFFSET
CONFIG_ATAPI
CONFIG_IDE_RESET
CONFIG_SYS_KWD_CONFIG
CONFIG_88F5182
CONFIG_BOARD_IS_OPENRD_BASE
CONFIG_BOARD_IS_OPENRD_CLIENT
CONFIG_BOARD_IS_OPENRD_ULTIMATE
CONFIG_D2NET_V2
CONFIG_FEROCEON
CONFIG_FEROCEON_88FR131
CONFIG_INETSPACE_V2
CONFIG_KW88F6192
CONFIG_KW88F6281
CONFIG_KW88F6702
CONFIG_NET2BIG_V2
CONFIG_NETSPACE_LITE_V2
CONFIG_NETSPACE_MAX_V2
CONFIG_NETSPACE_MINI_V2
CONFIG_NETSPACE_V2
CONFIG_SHEEVA_88SV131
At this point mv-plug-common.h is now only an include of mv-common.h so
remove that indirection.
CONFIG_USE_BOOTCOMMAND
CONFIG_BOOTCOMMAND
CONFIG_RAMBOOTCOMMAND
CONFIG_NFSBOOTCOMMAND
CONFIG_SKIP_LOWLEVEL_INIT
CONFIG_SKIP_LOWLEVEL_INIT_ONLY
In order to do this, we need to introduce SPL and TPL variants of these
options so that we can clearly disable these options only in SPL in some
cases, and both instances in other cases.
Now that we have consistent usage, migrate this symbol to Kconfig.
Reviewed-by: Rick Chen <rick@andestech.com>
As these boards support CONFIG_OF_CONTROL today, perform a basic
CONFIG_DM migration.
Cc: Stefan Roese <sr@denx.de>
CONFIG_NETCONSOLE
CONFIG_ENV_OVERWRITE
[trini: Rerun migration, remove some comments]
Have this symbol follow the pattern of all other such symbols.
This patch also removes a TODO from the code.
Reviewed-by: Chris Packham <judge.packham@gmail.com>
Signed-off-by: Trevor Woerner <twoerner@gmail.com>
Both symbols must be enabled when there is a raw NAND driver
selected. Also enable them when CONFIG_CMD_NAND is selected to avoid
breaking things when we'll further rework the MTD dependency
description.
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
[trini: Rebase and migrate a few more boards here]
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
CONFIG_ARCH_CPU_INIT
Acked-by: Chris Packham <chris.packham@alliedtelesis.co.nz>
Tested-by: Felix Brack <fb@ltec.ch>
CONFIG_USE_PREBOOT
CONFIG_PREBOOT
Both are together in one commit, since otherwise the former causes kconfig
to define the latter, which gives duplicate symbol errors.
Includes a manual fixup for CONFIG_PREBOOT in ids8313_defconfig since the
backslash lands in the wrong place. Similarly with socfpga_vining_fpga.
CONFIG_SYS_[DI]CACHE_OFF had been partially converted to Kconfig
parameters; only for the ARC architecture. This patch turns these two
parameters into Kconfig items everywhere else they are found.
All of the include/configs/* and defconfig changes in this patch are
for arm machines only. The Kconfig changes for arc, nds32, riscv,
and xtensa have been included since these symbols are found in code
under arch/{arc,nds32,riscv,xtensa}, however, no currently-defined
include/configs/* or defconfigs for these architectures exist which
include these symbols.
These results have been confirmed with tools/moveconfig.py.
Acked-by: Alexey Brodkin <abrodkin@snopsys.com>
Signed-off-by: Trevor Woerner <trevor@toganlabs.com>
[trini: Re-migrate for a few more boards]
Now that CMD_UBI does not select CMD_MTDPARTS we need to make platforms
that had been enabling it turn it on by hand. This exposed that we had
not yet migrated CMD_MTDPARTS fully, so do so now.
Fixes: 86dfa556d927 ("cmd: ubi: Remove useless call to mtdparts_init()")
CONFIG_MII
CONFIG_DRIVER_TI_EMAC
Acked-by: Jagan Teki <jagan@amarulasolutions.com>
We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
Import the dts files from Linux 4.17 and enable CONFIG_OF_CONTROL.
Signed-off-by: Chris Packham <judge.packham@gmail.com>
Add Kconfig for MVGBE and update boards to select this.
On the NIOS2 and Xtensa architectures, we do not have
CONFIG_SYS_TEXT_BASE set. This is a strict migration of the current
values into the defconfig and removing them from the headers.
I did not attempt to add more default values in and for now will leave
that to maintainers.
builds are broken because the size of the binary exceeds the limit.
Make some space by removing support for hardware partitioning as those
boards don't have any eMMC.
Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
These boards are on the boundary of "u-boot-nodtb.bin exceeds file
size limit" error.
Reduce the log-level to save memory footprint.
We move all instances of CONFIG_MTDIDS_DEFAULT and
CONFIG_MTDPARTS_DEFAULT from the header files to the defconfig files.
There's a few cases here where we need to expand upon what was in the
header file.
Tested-by: Adam Ford <aford173@gmail.com> #omap3_logic
Having this as a 'default y' is rather annoying because it doesn't
actually compile unless other options are defined in the board header:
../cmd/bootm.c: In function 'do_imls_nor':
../cmd/bootm.c:330:7: error: 'CONFIG_SYS_MAX_FLASH_BANKS' undeclared (first use in this function); did you mean 'CONFIG_SYS_MAX_FLASH_SECT'?
i < CONFIG_SYS_MAX_FLASH_BANKS; ++i, ++info) {
Make it 'default n' so people who develop new boards that start from a
blank defconfig have one less compilation failure to debug.
When we import code from Linux, with regular re-sync planned, we want
to use printk() and pr_*(). U-Boot does not support them in a clean
way. So, people end up with local macros, or compat headers here and
there, then we occasionally see build errors of definition conflicts.
We have include/linux/compat.h, but putting all sorts of unrelated
things into a single header is just a temporal workaround. Hence this
patch, to find the best home for all printk variants. If you want to
use printk() and friends, please include <linux/printk.h>. This header
is self-contained, and pulls in only a few headers.
When I was testing this clean-up, I noticed the image size exceeded
its platform limit on some boards. This is because all pr_*() that
were previously defined as no-op in include/linux/mtd/mtd.h (unless
CONFIG_MTD_DEBUG is set), are now enabled.
To make such boards happy, this commit also implements CONFIG_LOGLEVEL.
The concept is similar to the kernel parameter "loglevel". (Actually,
the Kconfig help message was taken from kernel-paremeter.txt of Linux)
Messages with a loglevel smaller than console loglevel will be printed.
The difference is the loglevel is build-time determined. To save the
image size, lower priority pr_*() are compiled out. I set the default
of CONFIG_LOGLEVEL to 6, i.e. pr_notice and higher priority messages
are compiled in.
I adjusted CONFIG_LOGLEVEL to avoid build error for some boards.
[trini: Add in SPL_LOGLEVEL that is the same as LOGLEVEL]
Migrate all remaining instances of CMD_NAND, CMD_NAND_TRIMFFS
CMD_NAND_LOCK_UNLOCK and CMD_NAND_TORTURE from the headers into the
defconfig files.
