path: root/configs/openrd_client_defconfig
2015-11-10Revive OpenRD targetsAlbert ARIBAUD
Revert commit 7a2c1b13 which dropped OpenRD boards. Assume maintainership of OpenRD. Remove OpenRD from scrapyard. Switch OpenRD to generic board. Switch to Thumb build. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2015-09-11arm: Remove openrd boardsSimon Glass
These boards have not been converted to generic board by the deadline. Remove them. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-08-30kirkwood: kconfig: refactor Kconfig and defconfigMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the KirkWood board select menu to kirkwood/Kconfig. Consolidate also common settings (CONFIG_SYS_CPU="arm926ejs" and CONFIG_SYS_SOC="kirkwood"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Prafulla Wadasdkar <prafulla@marvell.com> Cc: Luka Perkov <luka@openwrt.org>
