path: root/configs/omapl138_lcdk_defconfig
2016-09-26kconfig: introduce kconfig for UBIHeiko Schocher
move the UBI config options into Kconfig. Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Andrew F. Davis <afd@ti.com> Reviewed by: Evgeni Dobrev <evgeni at studio-punkt.com>
2015-05-10davinci: restore CONFIG_SPL=y to configs/omapl138_lcdk_defconfigPeter Howard
Signed-off-by: Peter Howard <phoward@gme.net.au>
2015-04-23davinci: add support for omapl138-lcdk boardPeter Howard
Signed-off-by: Peter Howard <phoward@gme.net.au> [trini: Add config file, update for ..._ether_addr() -> ..._ethaddr() rename] Signed-off-by: Tom Rini <trini@konsulko.com>
