path: root/configs/omapl138_lcdk_defconfig
2018-09-11ARM: davinci: omapl138_lcdk: Enable DM_MMCAdam Ford
With DM_MMC now available, this patch enables DM_MMC for the omapl138_lcdk in U-Boot and keeps the older style for SPL. Signed-off-by: Peter Howard <phoward@gme.net.au> Signed-off-by: Adam Ford <aford173@gmail.com>
2018-08-17Convert CONFIG_SYS_I2C_DAVINCI to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_SYS_I2C_DAVINCI Signed-off-by: Adam Ford <aford173@gmail.com>
2018-07-21Convert CONFIG_NAND_DAVINCI to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_NAND_DAVINCI Signed-off-by: Adam Ford <aford173@gmail.com>
2018-03-22configs: omapl138: Enable DM and DTLokesh Vutla
Enable Driver Model and Device-tree support for omapl138 board in U-Boot. Also enable DM_SERIAL and DM_I2C. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-03-22davinci: omapl138_lcdk: fix PLL0 frequencyDavid Lechner
commit 1601dd97edc6 ("davinci: omapl138_lcdk: increase PLL0 frequency") changed the PLL0 frequency to 456MHz, which is needed for the LCDC IP block. However, in doing so, it caused the PLLOUT clock to be outside of the allowable specifications given in the OMAP-L138 data sheet. (It says PLLOUT must be 600MHz max). It also uses a PLLM value outside of the range given in the TRM (it says PLLM must in the range 0 to 0x1f). So here is what we have currently: PLLOUT = 24 / (0 + 1) * (37 + 1) = 912MHz (out of spec) ^ ^ ^ CLKIN PREDIV PLLM (out of spec) input to PLLDIVn = 912 / (1 + 1) = 456MHz (desired result) ^ ^ PLLOUT POSTDIV This changes the PLLM value to 18 and the POSTDIV value to 0 so that PLLOUT is now within specification but we still get the desired result. PLLOUT = 24 / (0 + 1) * (18 + 1) = 456MHz (within spec) ^ ^ ^ CLKIN PREDIV PLLM input to PLLDIVn = 456 / (0 + 1) = 456MHz (desired result) ^ ^ PLLOUT POSTDIV Fixes: 1601dd97edc6 ("davinci: omapl138_lcdk: increase PLL0 frequency") Signed-off-by: David Lechner <david@lechnology.com> Reported-by: Sekhar Nori <nsekhar@ti.com> Tested-by: Sekhar Nori <nsekhar@ti.com>
2018-01-30Convert CONFIG_SYS_DV_CLKMODE et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_SYS_DV_CLKMODE CONFIG_SYS_DA850_PLL0_POSTDIV CONFIG_SYS_DA850_PLL0_PLLDIV1 CONFIG_SYS_DA850_PLL0_PLLDIV2 CONFIG_SYS_DA850_PLL0_PLLDIV3 CONFIG_SYS_DA850_PLL0_PLLDIV4 CONFIG_SYS_DA850_PLL0_PLLDIV5 CONFIG_SYS_DA850_PLL0_PLLDIV6 CONFIG_SYS_DA850_PLL0_PLLDIV7 CONFIG_SYS_DA850_PLL1_POSTDIV CONFIG_SYS_DA850_PLL1_PLLDIV1 CONFIG_SYS_DA850_PLL1_PLLDIV2 CONFIG_SYS_DA850_PLL1_PLLDIV3 Signed-off-by: Adam Ford <aford173@gmail.com>
2018-01-22Convert CONFIG_DAVINCI_SPI to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_DAVINCI_SPI Signed-off-by: Adam Ford <aford173@gmail.com>
2018-01-12configs: omapl138_lcdk: decrease the loglevel to reduce the size of the SPLJean-Jacques Hiblot
The changes in the MMC stack have increased its footprint up to the point were its breaks the generation of the SPL for this platform. Fix this by reducing the loglevel. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Peter Howard <phoward@gme.net.au>
2017-10-20Convert CONFIG_NAND_OMAP_GPMC et al and CONFIG_NAND_MXC to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_NAND_MXC CONFIG_NAND_OMAP_GPMC CONFIG_NAND_OMAP_GPMC_PREFETCH CONFIG_NAND_OMAP_ELM CONFIG_SPL_NAND_AM33XX_BCH CONFIG_SPL_NAND_SIMPLE CONFIG_SYS_NAND_BUSWIDTH_16BIT Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> [trini: Finish migration of CONFIG_SPL_NAND_SIMPLE, fix some build issues, add CONFIG_NAND_MXC so we can do CONFIG_SYS_NAND_BUSWIDTH_16BIT] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-10-05common: Drop LOGLEVEL to 4Tom Rini
While this came in with a default value of 6 I am lowering this to 4. The MTD/UBI code has a large number of error messages that we include now. In addition, "normally" warning messages are not included so this feels like a more natural level to have. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-10-04printk: collect printk stuff into <linux/printk.h> with loglevel supportMasahiro Yamada
When we import code from Linux, with regular re-sync planned, we want to use printk() and pr_*(). U-Boot does not support them in a clean way. So, people end up with local macros, or compat headers here and there, then we occasionally see build errors of definition conflicts. We have include/linux/compat.h, but putting all sorts of unrelated things into a single header is just a temporal workaround. Hence this patch, to find the best home for all printk variants. If you want to use printk() and friends, please include <linux/printk.h>. This header is self-contained, and pulls in only a few headers. When I was testing this clean-up, I noticed the image size exceeded its platform limit on some boards. This is because all pr_*() that were previously defined as no-op in include/linux/mtd/mtd.h (unless CONFIG_MTD_DEBUG is set), are now enabled. To make such boards happy, this commit also implements CONFIG_LOGLEVEL. The concept is similar to the kernel parameter "loglevel". (Actually, the Kconfig help message was taken from kernel-paremeter.txt of Linux) Messages with a loglevel smaller than console loglevel will be printed. The difference is the loglevel is build-time determined. To save the image size, lower priority pr_*() are compiled out. I set the default of CONFIG_LOGLEVEL to 6, i.e. pr_notice and higher priority messages are compiled in. I adjusted CONFIG_LOGLEVEL to avoid build error for some boards. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> [trini: Add in SPL_LOGLEVEL that is the same as LOGLEVEL] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-12Convert CONFIG_NAND to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_NAND Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Sync up a few more, add imply's] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-06-09configs: omapl138_lcdk: dont disable fat writeSekhar Nori
CONFIG_FAT_WRITE is imply'ed when CONFIG_CMD_FAT is selected (see CONFIG_TI_COMMON_CMD_OPTIONS). Dont disable it in defconfig so the imply takes effect and 'fatwrite' is available for users. Signed-off-by: Sekhar Nori <nsekhar@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-06-05configs: davinci: omapl138_lcdk: add random eth address supportAnna, Suman
Any TFTP or DHCP boot on the Davinci OMAP-L138 LCDK board requires that the 'ethaddr' variable be defined. There are no e-fuses to store the ethernet mac address for this platform, and neither is a MAC address reserved in any format. So enable random MAC address support so that networking boot can be supported. Signed-off-by: Suman Anna <s-anna@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
2017-06-03Kconfig: Migrate FS_FAT / FAT_WRITETom Rini
Now that these symbols are in Kconfig, migrate all users. Use imply on a number of platforms that default to having this enabled. As part of this we must migrate some straglers for CMD_FAT and DOS_PARTITION. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-31Kconfig: Finish migration of hashing commandsDaniel Thompson
Currently these (board agnostic) commands cannot be selected using menuconfig and friends. Fix this the obvious way. As part of this, don't muddle the meaning of CONFIG_HASH_VERIFY to mean both 'hash -v' and "we have a hashing command" as this makes the Kconfig logic odd. Signed-off-by: Daniel Thompson <daniel.thompson@linaro.org> [trini: Re-apply, add imply for a few cases, run moveconfig.py, also migrate CRC32_VERIFY] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-22Convert CONFIG_CMD_EEPROM et al to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_EEPROM CONFIG_CMD_EEPROM_LAYOUT CONFIG_EEPROM_LAYOUT_HELP_STRING Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Rework Kconfig logic slightly, define EEPROM location on TI eval platforms] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-22Convert CONFIG_SPL_BOARD_INIT to KconfigLey Foon Tan
This converts the following to Kconfig: CONFIG_SPL_BOARD_INIT Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com> [trini: Update the Kconfig logic] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-15davinci: omapl138_lcdk: drop custom prompt stringSekhar Nori
Drop custom command prompt string in favor of default used by U-Boot. This helps in easier automation setup across boards. Signed-off-by: Sekhar Nori <nsekhar@ti.com>
2017-05-12davinci: omapl138_lcdk: switch to using TI_COMMON_CMD_OPTIONSSekhar Nori
Now that we support using TI_COMMON_CMD_OPTIONS, we dont have to enable a number of commands explicitly in the defconfig if we enable TI_COMMON_CMD_OPTIONS. Enable TI_COMMON_CMD_OPTIONS and regenerate the defconfig using "make savedefconfig". CMD_GPIO has been kept disabled because there is no GPIO support (yet) on OMAP-L138 LCDK. Signed-off-by: Sekhar Nori <nsekhar@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-04-30Convert CONFIG_CMD_DIAG to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_DIAG Signed-off-by: Simon Glass <sjg@chromium.org> [trini: imply CMD_DIAG on some keymile configs] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-08davinci: omapl138_lcdk: enable some filesystem related commandsSekhar Nori
Enable some generic filesystem commands as well as disk partition related commands for OMAP-L138 LCDK board. These help in booting Linux from MMC/SD, for example. Signed-off-by: Sekhar Nori <nsekhar@ti.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-01-14omapl138_lcdk: enable SPL MMC supportFabien Parent
Enable SPL MMC support in order to allow to build a single u-boot image that is able to boot from MMC and NAND devices. Signed-off-by: Fabien Parent <fparent@baylibre.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-12-09davinci: omapl138_lcdk: boot from zImageFabien Parent
Stop booting legacy uImage and now boot zImage. Signed-off-by: Fabien Parent <fparent@baylibre.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-12-03davinci: omapl138_lcdk: add NAND SPL boot supportFabien Parent
NAND SPL boot was missing. Add it. The README specific to omapl138-lcdk is also removed because its content does not apply anymore, i.e. the generated AIS image can be flashed directly to the NAND without using any external tool to create and bootable AIS image. Signed-off-by: Fabien Parent <fparent@baylibre.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-12-03davinci: omapl138_lcdk: add u-boot sector for mmc/sd bootFabien Parent
Set the correct CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR value in order to be able to boot from MMC/SD. The SPL is stored at sector 0x75, while u-boot will follow at sector 0xb5. Signed-off-by: Fabien Parent <fparent@baylibre.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-09-26kconfig: introduce kconfig for UBIHeiko Schocher
move the UBI config options into Kconfig. Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Andrew F. Davis <afd@ti.com> Reviewed by: Evgeni Dobrev <evgeni at studio-punkt.com>
