path: root/configs/omap5_uevm_defconfig
2017-12-12ata: Migrate CONFIG_SCSI_AHCI to KconfigTuomas Tynkkynen
And use 'imply' liberally. Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi>
2017-10-03usb: gadget: Make g_dnl USB settings commonMaxime Ripard
The g_dnl USB settings for the vendor ID, product ID and manufacturer are actually common settings that can and should be shared by all the gadgets. Make them common by renaming them, and convert all the users. Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Lukasz Majewski <lukma@denx.de> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-09-08usb: net: migrate USB Ethernet adapters to KconfigChris Packham
This migrates ASIX, ASIX88179, MCS7830, RTL8152 and SMSC95XX to Kconfig. Update defconfigs. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-08usb: net: migrate CONFIG_USB_HOST_ETHER to KconfigChris Packham
CONFIG_USB_HOST_ETHER is the framework that the drivers are dependent on USB_HOST_ETHER. Use this as a menu and move the existing LAN75XX and LAN78XX options under new menu. Finally update the defconfigs that need CONFIG_USB_HOST_ETHER. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-13Convert CONFIG_OMAP3_SPI to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_OMAP3_SPI Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Minor comment tweaks] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-11Convert CONFIG_CMD_TCA642X to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_TCA642X Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-08-11Convert CONFIG_CMD_SPL to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_SPL Note that trats does not actually use SPL, so this option can no-longer be set. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-08-11configs: Resync with savedefconfigTom Rini
2017-07-31configs: Resync with savedefconfigTom Rini
2017-07-11Convert CONFIG_SCSI to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SCSI Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-06-03Kconfig: Migrate FS_FAT / FAT_WRITETom Rini
Now that these symbols are in Kconfig, migrate all users. Use imply on a number of platforms that default to having this enabled. As part of this we must migrate some straglers for CMD_FAT and DOS_PARTITION. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-15omap5: Migrate CONFIG_OMAP_PLATFORM_RESET_TIME_MAX_USEC to KconfigTom Rini
While in theory this value could be used in places outside of "omap5" (such as OMAP4), we only make use of it today in OMAP5, so place the Kconfig entry there. Given that Kconfig lets us provide a default, we drop CONFIG_DEFAULT_OMAP_RESET_TIME_MAX_USEC entirely. The contents of doc/README.omap-reset-time make a good help entry, so adjust them slightly and delete the file. Move the comment about range to where we use the value now, and have Kconfig enforce the upper bound. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-27ARM: omap2+: rename config to ARCH_OMAP2PLUS and consolidate KconfigMasahiro Yamada
In Linux, CONFIG_ARCH_OMAP2PLUS is used for OMAP2 or later SoCs. Rename CONFIG_ARCH_OMAP2 to CONFIG_ARCH_OMAP2PLUS to follow this naming. Move the OMAP2+ board/SoC choice down to mach-omap2/Kconfig to slim down the arch/arm/Kconfig level. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-01-11mmc: move more driver config options to KconfigMasahiro Yamada
Move (and rename) the following CONFIG options to Kconfig: CONFIG_DAVINCI_MMC (renamed to CONFIG_MMC_DAVINCI) CONFIG_OMAP_HSMMC (renamed to CONFIG_MMC_OMAP_HS) CONFIG_MXC_MMC (renamed to CONFIG_MMC_MXC) CONFIG_MXS_MMC (renamed to CONFIG_MMC_MXS) CONFIG_TEGRA_MMC (renamed to CONFIG_MMC_SDHCI_TEGRA) CONFIG_SUNXI_MMC (renamed to CONFIG_MMC_SUNXI) They are the same option names as used in Linux. This commit was created as follows: [1] Rename the options with the following command: find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \ -type f -print | xargs sed -i -e ' s/CONFIG_DAVINCI_MMC/CONFIG_MMC_DAVINCI/g s/CONFIG_OMAP_HSMMC/CONFIG_MMC_OMAP_HS/g s/CONFIG_MXC_MMC/CONFIG_MMC_MXC/g s/CONFIG_MXS_MMC/CONFIG_MMC_MXS/g s/CONFIG_TEGRA_MMC/CONFIG_MMC_SDHCI_TEGRA/g s/CONFIG_SUNXI_MMC/CONFIG_MMC_SUNXI/g ' [2] Commit the changes [3] Create entries in driver/mmc/Kconfig. (copied from Linux) [4] Move the options with the following command tools/moveconfig.py -y -r HEAD \ MMC_DAVINCI MMC_OMAP_HS MMC_MXC MMC_MXS MMC_SDHCI_TEGRA MMC_SUNXI [5] Sort and align drivers/mmc/Makefile for readability Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Marek Vasut <marex@denx.de>
2016-12-09configs: omap5_uevm_defconfig: Enable LPAE modeKeerthy
Enable Linear Physical Address Extension mode which is a prerequisite for hypervisor mode. Signed-off-by: Keerthy <j-keerthy@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-14spl: move SPL_OS_BOOT to KconfigHeiko Schocher
Move SPL_OS_BOOT to Kconfig and cleanup existing uses. Signed-off-by: Heiko Schocher <hs@denx.de>
2016-09-27dfu: Migrate to KconfigTom Rini
Introduce a hidden USB_FUNCTION_DFU Kconfig option and select it for CMD_DFU (as we must have the DFU command enabled to do anything DFU). Make all of the entries in drivers/dfu/Kconfig depend on CMD_DFU and add options for all of the back end choices that DFU can make use of. Cc: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Lukasz Majewski <l.majewski@samsung.com>
2016-09-20configs: Re-syncTom Rini
2016-04-20usb: gadget Move: CONFIG_G_DNL_* to KconfigSam Protsenko
And also reformat defconfigs using "make savedefconfig" rule. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-20usb: dwc3: Move CONFIG_USB_DWC3_PHY_* to KconfigSam Protsenko
2016-04-20usb: dwc3: Move CONFIG_USB_DWC3_OMAP to KconfigSam Protsenko
2016-04-20usb: dwc3: Move CONFIG_USB_DWC3_GADGET/HOST to KconfigSam Protsenko
Description was borrowed from kernel dwc3 Kconfig. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_DOWNLOAD to KconfigSam Protsenko
While at it, remove obsolete CONFIG_USBDOWNLOAD_GADGET option from some config headers. This is also probably fixes am335x_baltos board. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_DUALSPEED to KconfigSam Protsenko
Move CONFIG_USB_GADGET_DUALSPEED option to Kconfig and make all UDC controllers select USB_GADGET_DUALSPEED: - add next options to Kconfig selecting USB_GADGET_DUALSPEED: - USB_GADGET_ATMEL_USBA - USB_GADGET_DWC2_OTG - USB_DWC3 - CI_UDC - make USB_MUSB_GADGET select USB_GADGET_DUALSPEED While at it, make some related fixes: - remove DUALSPEED from configs that don't enable gadget support: - kwb.h - tseries.h - add missing USB_GADGET option to next configs: - novena_defconfig - pcm051_rev*_defconfig - xfi3_defconfig Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-03-25usb: gadget: Move CONFIG_USB_GADGET to KconfigSam Protsenko
The description was borrowed from kernel. "tristate" type was changed to "bool" (I believe we don't support modules for u-boot yet, right?). CONFIG_USB_GADGET requires CONFIG_USB to be defined too, so add it along as well. Definitions were added to defconfig files in a way that "make savedefconfig" generates exactly the same file as used defconfig. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> [trini: Add zynq_zc702 conversion] Signed-off-by: Tom Rini <trini@konsulko.com>
2014-08-30omap5: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the OMAP5 board select menu to omap5/Kconfig. Move also common settings (CONFIG_SYS_CPU="armv7" and CONFIG_SYS_SOC="omap5"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Tom Rini <trini@ti.com> Cc: Lokesh Vutla <lokeshvutla@ti.com>
