path: root/configs/omap4_panda_defconfig
2014-08-30omap4: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the OMAP4 board select menu to omap4/Kconfig. Move also common settings (CONFIG_SYS_CPU="armv7" and CONFIG_SYS_SOC="omap4"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Tom Rini <trini@ti.com> Cc: Lokesh Vutla <lokeshvutla@ti.com>
