path: root/configs/omap3_logic_defconfig
2018-05-30fastboot: Move fastboot to drivers/fastbootAlex Kiernan
Separate CMD_FASTBOOT from FASTBOOT and move code and configuration to drivers/fastboot. Switch dependencies on FASTBOOT to USB_FUNCTION_FASTBOOT as anyone who wants FASTBOOT before this series wants USB_FUNCTION_FASTBOOT. Split USB_FUNCTION_FASTBOOT from FASTBOOT so they retain their existing behaviour. Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-03-16Convert all of CONFIG_CONS_INDEX to KconfigTom Rini
This converts the following to Kconfig: CONFIG_CONS_INDEX We have existing entries for this option in a number of places, with different guards on them. They're also sometimes used for things not directly inside of the serial driver. First, introduce a new symbol to guard the use of CONFIG_CONS_INDEX, so that in the case where we don't need this for the serial driver, but for some other use, we can still do it. Next, consolidate all of these into the single entry in drivers/serial/Kconfig. Finally, introduce CONS_INDEX_[023456] so that we can imply a correct value here to make the defconfig side of this smaller. Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Rework a lot of the logic here, such that I took authorship from Adam, but kept his S-o-B line] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-03-14omap3_logic: Enable DM_SPIAdam Ford
With the introduction of ("Boards,Need,to,Switch,DM] spi: omap3_spi: Full dm conversion"), Driver Model for McSPI is now available on the omap3. This enables the config by default on omap3_logic boards. Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2018-02-23omap3_logic: Fix Environmental locationAdam Ford
For the omap3_logic boards, the environment is always in NAND. This removes the ENV_IS_IN_FAT flag to eliminate the extra chatter. Signed-off-by: Adam Ford <aford173@gmail.com>
2018-02-23configs: Re-sync with CONFIG_DISTRO_DEFAULTSTom Rini
A number of platforms include config_distro_defaults.h but do not enable CONFIG_DISTRO_DEFAULTS. As they plainly intended to, set that flag and re-sync config files. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-01-22Convert CONFIG_TWL4030_USB to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_TWL4030_USB Signed-off-by: Adam Ford <aford173@gmail.com>
2018-01-22Convert CONFIG_USB_MUSB_HCD et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_USB_MUSB_HCD CONFIG_USB_MUSB_UDC CONFIG_USB_DAVINCI CONFIG_USB_OMAP3 CONFIG_USB_DA8XX CONFIG_USB_AM35X Signed-off-by: Adam Ford <aford173@gmail.com>
2018-01-22Convert CONFIG_USB_MUSB_OMAP2PLUS et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_USB_MUSB_OMAP2PLUS CONFIG_USB_MUSB_AM35X CONFIG_USB_MUSB_DSPS CONFIG_USB_MUSB_PIO_ONLY Signed-off-by: Adam Ford <aford173@gmail.com>
2018-01-22ARM: omap3_logic: Enable SPL_OF_CONTROL and SPL_OF_PLATDATAAdam Ford
The SPL doesn't have much room, so in order to support OF_CONTROL in SPL, we need the extra functionality of SPL_OF_PLATDATA. Adding these features allows us to remove a small part of code without losing the serial port during SPL. Signed-off-by: Adam Ford <aford173@gmail.com>
2017-12-12omap3_logic: Increase CMD_SPL_WRITE_SIZEAdam Ford
The SPL-OS partition is 0x20000, so let's make CONFIG_CMD_SPL_WRITE_SIZE same size. This should allow for better falcon mode operation. Signed-off-by: Adam Ford <aford173@gmail.com>
2017-10-20net: Add SMC911X driver to Kconfig, convertAdam Ford
We add the various SMC91XX symbols to drivers/net/Kconfig and then this converts the following to Kconfig: CONFIG_SMC911X CONFIG_SMC911X_BASE CONFIG_SMC911X_16_BIT CONFIG_SMC911X_32_BIT Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Apply to the rest of the tree, re-squash old and new patch] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-10-20Convert CONFIG_NAND_OMAP_GPMC et al and CONFIG_NAND_MXC to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_NAND_MXC CONFIG_NAND_OMAP_GPMC CONFIG_NAND_OMAP_GPMC_PREFETCH CONFIG_NAND_OMAP_ELM CONFIG_SPL_NAND_AM33XX_BCH CONFIG_SPL_NAND_SIMPLE CONFIG_SYS_NAND_BUSWIDTH_16BIT Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> [trini: Finish migration of CONFIG_SPL_NAND_SIMPLE, fix some build issues, add CONFIG_NAND_MXC so we can do CONFIG_SYS_NAND_BUSWIDTH_16BIT] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-10-03cmd: fastboot: Rework fastboot dependencyMaxime Ripard
Fastboot need a bunch of options to be operating properly, such as the g_dnl gadget, the fastboot command, and some options that make sense. Since fastboot is now part of Kconfig, make sure we have them right. That will also reduce the boilerplate in the defconfigs. Reviewed-by: Łukasz Majewski <lukma@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-10-03usb: gadget: Make g_dnl USB settings commonMaxime Ripard
The g_dnl USB settings for the vendor ID, product ID and manufacturer are actually common settings that can and should be shared by all the gadgets. Make them common by renaming them, and convert all the users. Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Lukasz Majewski <lukma@denx.de> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-10-03usb: gadget: Convert USB_ETHER to KconfigMaxime Ripard
The USB Ethernet gadget option has not yet been moved to Kconfig, let's deal with that. Reviewed-by: Łukasz Majewski <lukma@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-09-29TI: ARCH_OMAP2PLUS: Enable SPL_STACK_R and provide default valueTom Rini
On ARCH_OMAP2PLUS platforms we know what the DDR layout is going to be, and that it is safe to use SPL_STACK_R and provide a default value for it. select this and re-sync the defconfigs. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-09-13omap3: omap3_logic: Finish enabling fastboot on MUSBAdam Ford
Either the USB and Fastboot were never finished, or somehow it got lost. This puts enough hooks back into omap3logic to enable fastboot and hopefully prepare it for Kconfig conversion. Signed-off-by: Adam Ford <aford173@gmail.com>
2017-09-02omap3_logic: Move CONFIG_SYS_NAND_U_BOOT_OFFS to KconfigAdam Ford
Manually enable SYS_NAND_U_BOOT_LOCATIONS. Set CONFIG_SYS_NAND_U_BOOT_OFFS=0x80000 and remove it from header Signed-off-by: Adam Ford <aford173@gmail.com>
2017-09-01Convert CONFIG_BCH to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_BCH Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-01Kconfig: Migrate all of cmd/fastboot/Kconfig to defconfigsTom Rini
- Move ANDROID_IMAGE_SUPPORT to top level Kconfig under images as it's not strictly part of fastboot. - Add some defaults for the fastboot buffer location and size - Migrate all options listed in cmd/fastboot/Kconfig - Cleanup the README Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-13Convert CONFIG_OMAP3_SPI to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_OMAP3_SPI Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Minor comment tweaks] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-12Convert CONFIG_NAND to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_NAND Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Sync up a few more, add imply's] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-11Convert CONFIG_CMD_SPL_NAND_OFS to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_SPL_NAND_OFS Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-08-11Convert CONFIG_CMD_SPL to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_SPL Note that trats does not actually use SPL, so this option can no-longer be set. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-07-31ti: Default to ENV_IS_IN_FAT if MMC_OMAP_HSTom Rini
When we have MMC available we assume that we want to put the env as a file on FAT. Cc: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-22Convert CONFIG_CMD_EEPROM et al to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_EEPROM CONFIG_CMD_EEPROM_LAYOUT CONFIG_EEPROM_LAYOUT_HELP_STRING Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Rework Kconfig logic slightly, define EEPROM location on TI eval platforms] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-15omap3: omap3_logic: switch to using TI_COMMON_CMD_OPTIONAdam Ford
Enable TI_COMMON_CMD_OPTIONS and remove similar options from the defconfig. Updated with savedefconfig CMD_USB isn't enabled yet. I have some testing to do with musb. Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-05-09omap3_logic: Add Device Tree Support and more DM driversAdam Ford
This patch also removes all the excessive code for NS16550 intiailization as the device tree can do that now. This also adds DM_I2C and DM_MMC since the overlying drivers have the built-in support already. The corresponding include/config/omap3_logic.h also reduced in size due to the new device tree support. Signed-off-by: Adam Ford <aford173@gmail.com> Changes in V2: Retain Auto-detect ability between SOM-LV and Torpedo Split this off from the device sub submissions
2017-04-27ARM: omap2+: rename config to ARCH_OMAP2PLUS and consolidate KconfigMasahiro Yamada
In Linux, CONFIG_ARCH_OMAP2PLUS is used for OMAP2 or later SoCs. Rename CONFIG_ARCH_OMAP2 to CONFIG_ARCH_OMAP2PLUS to follow this naming. Move the OMAP2+ board/SoC choice down to mach-omap2/Kconfig to slim down the arch/arm/Kconfig level. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-03-08omap3_logic: Move SPL Stack into SDRAMAdam Ford
A previous patch broke the board. This patch will add missing part from the previous patch and also move the SPL Stack into SDRAM at 0x82000000. Tested with GCC 4.8.2 and GCC 6.2 Fixes: 0959649dc6d9 ("omap3_logic: Switch to simple malloco in SPL") Signed-off-by: Adam Ford <aford173@gmail.com> Changes in V2: - Keep CONFIG_SPL_SYS_MALLOC_SIMPLE - Add CONFIG_SYS_MALLOC_F_LEN=0x2000 (8 MB)
2017-02-09Merge branch 'master' of git://git.denx.de/u-boot-mmcTom Rini
2017-02-09omap3_logic: Switch to simple malloco in SPLTom Rini
To save more space, switch to simple malloc here. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-02-09drivers: mmc: omap_hsmmc: Fix IO Buffer on OMAP36xxAdam Ford
On the OMAP36xx/37xx the CONTROL_WKUP_CTRL register has a field (bit 6) named GPIO_IO_PWRDNZ. If 0, the IO buffers which are related to GPIO_126, 127 and 129 are disabled. Some boards may need this for MMC. After the PBIAS is configured, this bit should be set high to enable these GPIO pins. Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-01-11mmc: move more driver config options to KconfigMasahiro Yamada
Move (and rename) the following CONFIG options to Kconfig: CONFIG_DAVINCI_MMC (renamed to CONFIG_MMC_DAVINCI) CONFIG_OMAP_HSMMC (renamed to CONFIG_MMC_OMAP_HS) CONFIG_MXC_MMC (renamed to CONFIG_MMC_MXC) CONFIG_MXS_MMC (renamed to CONFIG_MMC_MXS) CONFIG_TEGRA_MMC (renamed to CONFIG_MMC_SDHCI_TEGRA) CONFIG_SUNXI_MMC (renamed to CONFIG_MMC_SUNXI) They are the same option names as used in Linux. This commit was created as follows: [1] Rename the options with the following command: find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \ -type f -print | xargs sed -i -e ' s/CONFIG_DAVINCI_MMC/CONFIG_MMC_DAVINCI/g s/CONFIG_OMAP_HSMMC/CONFIG_MMC_OMAP_HS/g s/CONFIG_MXC_MMC/CONFIG_MMC_MXC/g s/CONFIG_MXS_MMC/CONFIG_MMC_MXS/g s/CONFIG_TEGRA_MMC/CONFIG_MMC_SDHCI_TEGRA/g s/CONFIG_SUNXI_MMC/CONFIG_MMC_SUNXI/g ' [2] Commit the changes [3] Create entries in driver/mmc/Kconfig. (copied from Linux) [4] Move the options with the following command tools/moveconfig.py -y -r HEAD \ MMC_DAVINCI MMC_OMAP_HS MMC_MXC MMC_MXS MMC_SDHCI_TEGRA MMC_SUNXI [5] Sort and align drivers/mmc/Makefile for readability Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Marek Vasut <marex@denx.de>
