These config targets were added well before the Kconfig migration began
as a way to demonstrate how to make these platforms work with cut down
features. At this point in time they no longer serve a good purpose so
remove them.
As the help message of CONFIG_BOOTDELAY says, CONFIG_BOOTDELAY=-2
means the autoboot with no delay, with no abort check even if
CONFIG_ZERO_BOOTDELAY_CHECK is defined.
To sum up, the autoboot behaves as follows:
[1] CONFIG_BOOTDELAY=0 && CONFIG_ZERO_BOOTDELAY_CHECK=y
autoboot with no delay, but you can abort it by key input
[2] CONFIG_BOOTDELAY=0 && CONFIG_ZERO_BOOTDELAY_CHECK=n
autoboot with no delay, with no check for abort
[3] CONFIG_BOOTDELAY=-1
disable autoboot
[4] CONFIG_BOOTDELAY=-2
As you notice, [2] and [4] come to the same result, which means we
do not need CONFIG_ZERO_BOOTDELAY_CHECK. We can control all the
cases only by CONFIG_BOOTDELAY, like this:
[2] CONFIG_BOOTDELAY=-1
disable autoboot
[3] CONFIG_BOOTDELAY=-2
This commit converts the logic as follow:
--> CONFIG_BOOTDELAY=-2
Acked-by: Vladimir Zapolskiy <vz@mleia.com>
Acked-by: Christian Riesch <christian.riesch@omicronenergy.com>
Acked-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
With updated moveconfig.py and an better default, re-generate
the migration of BOOTDELAY to the defconfig.
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
Some boards' defconfigs are disordered. Reorder them.
Add option to set shell prompt string from menuconfig and migrate
boards globally.
The migration is done as follows:
- Boards that explicitly and unconditionally set CONFIG_SYS_PROMPT had the
entry moved to their defconfig files.
- Boards that defined some kind of #ifdef logic which selects the
CONFIG_SYS_PROMPT (for example qemu-mips) got an #undef CONFIG_SYS_PROMPT
right before the #ifdef logic and were left alone.
- This change forces CONFIG_SYS_PROMPT to be a per board decision, and thus
CONFIG_SYS_PROMPT was removed from all <soc>_common.h and <arch>_common.h
files. This results in a streamlined default value across platforms, and
includes the following files: spear-common, sunxi-common, mv-common,
ti_armv7_common, tegra-common, at91-sama5_common, and zynq-common.
- Boards that relied on <arch/soc>_common.h values of CONFIG_SYS_PROMPT were
not updated in their respective defconfig files under the assumption that
since they did not explicitly define a value, they're fine with whatever
the default is.
- On the other hand, boards that relied on a value defined in some
<boards>_common.h file such as woodburn_common, rpi-common,
bur_am335x_common, ls2085a_common, siemens_am33x_common, and
omap3_evm_common, had their values moved to the respective defconfig files.
- The define V_PROMPT was removed, since it is not used anywhere except for
assigning a value for CONFIG_SYS_PROMPT.
Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
Cc: Igor Grinberg <grinberg@compulab.co.il>
Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
[trini: Add spring, sniper, smartweb to conversion]
them from include/configs.
This also selects CONFIG_NET for any CONFIG_CMD_NET board.
Remove the imx default for CONFIG_NET.
This moves the config that was defined by 60296a8 (commands: add more
command entries in Kconfig).
In order to reduce merge conflicts and to maintain the simplest possible
defconfig files, we should be using the savedefconfig feature of Kconfig
every time a new feature is added. This keeps the defconfig settings to
a minimum (only those things not default) and keeps them in the same
order as the Kconfig options.
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
As mentioned in the previous commit, adding default values in each
Kconfig causes problems because it does not co-exist with the
"depends on" syntax. (Please note this is not a bug of Kconfig.)
We should not do so unless we have a special reason. Actually,
for CONFIG_DM*, we have no good reason to do so.
Generally, CONFIG_DM is not a user-configurable option. Once we
convert a driver into Driver Model, the board only works with Driver
Model, i.e. CONFIG_DM must be always enabled for that board.
So, using "select DM" is more suitable rather than allowing users to
modify it. Another good thing is, Kconfig warns unmet dependencies
for "select" syntax, so we easily notice bugs.
Actually, CONFIG_DM and other related options have been added
without consistency: some into arch/*/Kconfig, some into
board/*/Kconfig, and some into configs/*_defconfig.
This commit prefers "select" and cleans up the following issues.
[1] Never use "CONFIG_DM=n" in defconfig files
It is really rare to add "CONFIG_FOO=n" to disable CONFIG options.
It is more common to use "# CONFIG_FOO is not set". But here, we
do not even have to do it.
Less than half of OMAP3 boards have been converted to Driver Model.
Adding the default values to arch/arm/cpu/armv7/omap3/Kconfig is
weird. Instead, add "select DM" only to appropriate boards, which
eventually eliminates "CONFIG_DM=n", etc.
[2] Delete redundant CONFIGs
Sandbox sets CONFIG_DM in arch/sandbox/Kconfig and defines it again
in configs/sandbox_defconfig.
Likewise, OMAP3 sets CONFIG_DM arch/arm/cpu/armv7/omap3/Kconfig and
defines it also in omap3_beagle_defconfig and devkit8000_defconfig.
Since commit e02ee2548afe (kconfig: switch to single .config
configuration), the prefixes in defconfig files such as "+S:",
"+ST:", etc., are meaningless.
This commit was generated by the following command:
find configs -name '*_defconfig' | xargs sed -i 's/^+*S*T*://'
Remove driver model CONFIGs from the board config headers and use Kconfig
instead.
Becuase the board select menu in arch/arm/Kconfig is too big,
move the OMAP3 board select menu to omap3/Kconfig.
Move also common settings (CONFIG_SYS_CPU="armv7" and
CONFIG_SYS_SOC="omap3
Reviewed-by: Tom Rini <trini@ti.com>
This commit adds:
- arch/${ARCH}/Kconfig
provide a menu to select target boards
- board/${VENDOR}/${BOARD}/Kconfig or board/${BOARD}/Kconfig
set CONFIG macros to the appropriate values for each board
- configs/${TARGET_BOARD}_defconfig
default setting of each board
(This commit was automatically generated by a conversion script
based on boards.cfg)
In Linux Kernel, defconfig files are located under
arch/${ARCH}/configs/ directory.
It works in Linux Kernel since ARCH is always given from the
command line for cross compile.
But in U-Boot, ARCH is not given from the command line.
Which means we cannot know ARCH until the board configuration is done.
That is why all the "*_defconfig" files should be gathered into a
single directory ./configs/.
