path: root/configs/omap35_logic_defconfig
2019-05-18ARM: omap3_logic/omap35_logic: Enable GPIO in SPLAdam Ford
The MMC controller enabled card detect, so this patch enables the GPIO driver in SPL to support it. Signed-off-by: Adam Ford <aford173@gmail.com>
2019-05-01Merge tag 'u-boot-imx-20190426' of git://git.denx.de/u-boot-imxTom Rini
Porting to DM and i.MX8 ------------------------ - warp7 to DM - kp_imx53 to DM - Warnings in DT - MX8QM support - colibri-imx6ull to DM - imx7d-pico to DM - ocotp for MX8
2019-04-25ARM: omap3_logic: Enable UUIDAdam Ford
Instead of hardcoding the mmcroot to /dev/mmcblkX, use the UUID method. Signed-off-by: Adam Ford <aford173@gmail.com>
2019-02-19ARM: omap3_logic: Enable SPL booting device treeAdam Ford
With the generic omap3-u-boot.dtsi file available, this patch increased the memory of the various incarnations of the omap3_logic board, and points their respective u-boot.dtsi files to the newly created generic one, and removes the PLATDATA from the board file. These are all done at once because the're all utilizing the same omap3logic.c board file. Signed-off-by: Adam Ford <aford173@gmail.com>
2019-01-07configs: Resync with savedefconfigTom Rini
2018-12-12ARM: omap3_logic/omap35_logic: Move to DM_USBAdam Ford
The existing config is setup as a gadget but it doesn't use DM_USB. This patch converts all boards to DM_USB, but as host. As host, it is able to mount USB drives and browse them. Signed-off-by: Adam Ford <aford173@gmail.com>
2018-11-16ARM: omap3_logic: Remove SPL_OF_CONTROL and OF_PLATDATAAdam Ford
After the recomendation, some testing shows like these are unnecessary. Suggested-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Signed-off-by: Adam Ford <aford173@gmail.com>
2018-11-16ARM: omap3_logic: Make CONFIG_SYS_TEXT_BASE match README.omap3Adam Ford
README.omap3 has two options. For option 1, CONFIG_SYS_TEXT_BASE is set to 0x80100000. Option 2 lists 0x80008000. The existing value is neither of these, so this patch makes it equivalent to Option 1. Signed-off-by: Adam Ford <aford173@gmail.com>
2018-10-06ARM: DTS: Add Logic PD OMAP35/DM37 SOM-LV and OMAP35 TorpedoAdam Ford
With the device trees doing most of the work of pin-muxing and DM doing much of the peripheral initialization, this creates new defconfig files for each of the Logic PD variants with proper register settings/pin-muxing. Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Update MAINTAINERS entry] Signed-off-by: Tom Rini <trini@konsulko.com>
