CONFIG_ENV_OVERWRITE
[trini: Rerun migration, remove some comments]
Move CONFIG_SET_DFU_ALT_INFO into Kconfig done by moveconfig.py.
Acked-by: Lukasz Majewski <lukma@denx.de>
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
XOM pins provide information for iROM bootloader about the boot device.
Those pins are mapped to lower bits of OP_MODE register (0x10000008),
which is common for all Exynos SoC variants. Set the default MMC device id
to reflect the boot device selected by XOM[7:5] pins (2 for the SD or 0 for
the eMMC).
Like in Linux, just use CONFIG_MTD to compile the MTD stack.
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
CONFIG_ARCH_CPU_INIT
Acked-by: Chris Packham <chris.packham@alliedtelesis.co.nz>
Tested-by: Felix Brack <fb@ltec.ch>
CONFIG_SUPPORT_EMMC_BOOT
As requested by Michal Simek <michal.simek@xilinx.com>, these boards
have no eMMC so CONFIG_SUPPORT_EMMC_BOOT has not been migrated:
xilinx_zynqmp_zc1275_revB
xilinx_zynqmp_zc1751_xm018_dc4
xilinx_zynqmp_zc1751_xm019_dc5
xilinx_zynqmp_zcu100_revC
xilinx_zynqmp_zcu102_rev1_0
xilinx_zynqmp_zcu102_revA
xilinx_zynqmp_zcu102_revB
xilinx_zynqmp_zcu104_revA
xilinx_zynqmp_zcu104_revC
xilinx_zynqmp_zcu106_revA
xilinx_zynqmp_zcu111_revA
Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
Acked-by: Patrick Delaunay <patrick.delaunay@st.com>
Acked-by: Ramon Fried <ramon.fried@gmail.com>
Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Tested-by: Sébastien Szymanski <sebastien.szymanski@armadeus.com>
This commit enables support for I2C S3C424X0 driver.
Signed-off-by: Anand Moon <linux.amoon@gmail.com>
Printing the "Type" of board requires proper detection of revision which
can happen only late because regulators are needed.
Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org>
Tested-by: Anand Moon <linux.amoon@gmail.com>
CONFIG_BOARD_TYPES
Reviewed-by: Lukasz Majewski <lukma@denx.de>
Acked-by: Alexey Brodkin <abrodkin@synopsys.com>
Reviewed-by: Minkyu Kang <mk7.kang@samsung.com>
Odroid HC2 board is based on Odroid XU4 board, like the Odroid HC1.
The linux kernel does not provide a hc2 DTB so the hc1 DTB is also used
for the Odroid HC2.
Resend because MUA changed whitespace.
Signed-off-by: Dirk Meul <dirk.meul@rwth-aachen.de>
Acked-by: Marek Szyprowski <m.szyprowski@samsung.com>
CONFIG_MISC_INIT_R
[trini: Update the defaults logic slightly]
We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
This commit enables support for DW_MMC running with driver model.
Signed-off-by: Lukasz Majewski <lukma@denx.de>
The Exynos5422 is solely using DW MMC IP block to support eMMC/SD devices,
hence the SDHCI code doesn't need to be compiled it.
Convert CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG to Kconfig
Reviewed-by: Petr Vorel <petr.vorel@gmail.com>
Reviewed-by: Petr Vorel <petr.vorel at gmail.com>
On the NIOS2 and Xtensa architectures, we do not have
CONFIG_SYS_TEXT_BASE set. This is a strict migration of the current
values into the defconfig and removing them from the headers.
I did not attempt to add more default values in and for now will leave
that to maintainers.
This commit moves USB_FUNCTION_THOR config to Kconfig.
Acked-by: Michal Simek <michal.simek@xilinx.com>
Enable the CONFIG_CMD_REGULATOR and CONFIG_DM_REGULATOR_S2MPS11.
Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
Odroid HC1 board is based on Odroid XU4 board, but it has no HDMI,
no eMMC, no build-in USB3.0 hub, no extension port pins, and no GPIO
button. USB3.0 ports are used for build-in JMicron USB to SATA bridge
and Gigabit R8152 ethernet chips. HC1 uses only passive cooling.
This patch also updates Odroid's ADCmax array and reduces ADC tolerance
to 1% to ensure that XU4 and HC1 revisions are properly detected.
I've tested this with XU3, XU3-lite, XU4 and HC1 boards. In case of my test
boards I got following values from ADC register: 372, 370, 1281 and 1313.
Tested-by: Krzysztof Kozlowski <krzk@kernel.org>
We add the various SMC91XX symbols to drivers/net/Kconfig and then this
CONFIG_SMC911X
CONFIG_SMC911X_BASE
CONFIG_SMC911X_16_BIT
CONFIG_SMC911X_32_BIT
[trini: Apply to the rest of the tree, re-squash old and new patch]
Having this as a 'default y' is rather annoying because it doesn't
actually compile unless other options are defined in the board header:
../cmd/bootm.c: In function 'do_imls_nor':
../cmd/bootm.c:330:7: error: 'CONFIG_SYS_MAX_FLASH_BANKS' undeclared (first use in this function); did you mean 'CONFIG_SYS_MAX_FLASH_SECT'?
i < CONFIG_SYS_MAX_FLASH_BANKS; ++i, ++info) {
Make it 'default n' so people who develop new boards that start from a
blank defconfig have one less compilation failure to debug.
The g_dnl USB settings for the vendor ID, product ID and manufacturer are
actually common settings that can and should be shared by all the gadgets.
Make them common by renaming them, and convert all the users.
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
CONFIG_USB_HOST_ETHER is the framework that the drivers are dependent on
USB_HOST_ETHER. Use this as a menu and move the existing LAN75XX and
LAN78XX options under new menu. Finally update the defconfigs that need
CONFIG_USB_HOST_ETHER.
Signed-off-by: Chris Packham <judge.packham@gmail.com>
CONFIG_CMD_THOR_DOWNLOAD
Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
CONFIG_ENV_IS_IN_MMC
CONFIG_ENV_IS_IN_NAND
CONFIG_ENV_IS_IN_UBI
CONFIG_ENV_IS_NOWHERE
In fact this already exists for sunxi as a 'choice' config. However not
all the choices are available in Kconfig yet so we cannot use that. It
would lead to more than one option being set.
In addition, one purpose of this series is to allow the environment to be
stored in more than one place. So the existing choice is converted to a
normal config allowing each option to be set independently.
There are not many opportunities for Kconfig updates to reduce the size of
this patch. This was tested with
./tools/moveconfig.py -i CONFIG_ENV_IS_IN_MMC
And then manual updates. This is because for CHAIN_OF_TRUST boards they
can only have ENV_IS_NOWHERE set, so we enforce that via Kconfig logic
now.
Remove the CONFIG_I2C_COMPAT, instead enable the CONFIG_SYS_I2C_S3C24X0.
Migrate the rest of the users of CONFIG_USB_EHCI_HCD over to Kconfig.
For a few SoCs, imply or default y this if USB is enabled. In some
cases we had not already migrated to CONFIG_USB so do that as well.
This commit was created as follows:
[1] Rename the option with the following command:
find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \
-type f -print | xargs sed -i -e 's/CONFIG_DWMMC/CONFIG_MMC_DW/g'
[2] create the entry for MMC_DW in drivers/mmc/Kconfig
(the prompt and help were copied from Linux)
[3] run "tools/moveconfig.py -y MMC_DW"
[4] add "depends on MMC_DW" to the MMC_DW_ROCKCHIP entry
[5] Clean-up doc/README.socfpga by hand
While I moved the options, I also renamed them so that they are all
prefixed with MMC_SDHCI_.
This commit was created in the following steps.
[1] Rename with the following command
s/CONFIG_MMC_SDMA/CONFIG_MMC_SDHCI_SDMA/g
s/CONFIG_BCM2835_SDHCI/CONFIG_MMC_SDHCI_BCM2835/g
s/CONFIG_KONA_SDHCI/CONFIG_MMC_SDHCI_KONA/g
s/CONFIG_MV_SDHCI/CONFIG_MMC_SDHCI_MV/g
s/CONFIG_S5P_SDHCI/CONFIG_MMC_SDHCI_S5P/g
s/CONFIG_SPEAR_SDHCI/CONFIG_MMC_SDHCI_SPEAR/g
[2] create the Kconfig entries in drivers/mmc/Kconfig
[3] Move the options by the following command
tools/moveconfig.py -y MMC_SDHCI_SDMA MMC_SDHCI_BCM2835 \
MMC_SDHCI_KONA MMC_SDHCI_MV MMC_SDHCI_S5P MMC_SDHCI_SPEAR
[4] Sort drivers/mmc/Makefile for readability
Move CONFIG_SDHCI to Kconfig and rename it to CONFIG_MMC_SDHCI.
My motivation for the rename is, ultimately, to make all the MMC
options prefixed with MMC_ and SDHCI options with MMC_SDHCI_,
like Linux.
[1] Rename the config option with the following command:
-type f -print | xargs sed -i -e 's/CONFIG_SDHCI/CONFIG_MMC_SDHCI/g'
[2] create the entry for MMC_SDHCI in drivers/mmc/Kconfig
[3] run "tools/moveconfig.py -y MMC_SDHCI"
[4] add "depends on MMC_SDHCI" to existing SDHCI driver entries
Generated by "tools/moveconfig -s".
This will make config moves easier.
A number of platforms had been using the distro default feature before
it was moved to Kconfig but did not enable the new Kconfig option when
it was enabled. This caused a regression in terms of features and this
introduces breakage when more things move to Kconfig.
CONFIG_SYS_CONSOLE_IS_IN_ENV
CONFIG_CONSOLE_MUX
[trini: Re-order, re-migrate]
Move these option to Kconfig and tidy up existing uses.
The Power PC boards don't have a suitable common element: the common header
files don't appear to line up with the Kconfig files as far as I can tell.
This results in a lot of defconfig changes.
Reviewed-by: Jagan Teki <jteki@openedev.com>
[trini: Re-migrate, update common/console.c logic]
Introduce a hidden USB_FUNCTION_DFU Kconfig option and select it for
CMD_DFU (as we must have the DFU command enabled to do anything DFU).
Make all of the entries in drivers/dfu/Kconfig depend on CMD_DFU and add
options for all of the back end choices that DFU can make use of.
Cc: Lukasz Majewski <l.majewski@samsung.com>
Acked-by: Lukasz Majewski <l.majewski@samsung.com>
Move the config IDENT_STRING to Kconfig and migrate all boards
[sivadur: Migrate zynq boards]
Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
[trini: Update configs, add some default to sunxi Kconfig]
