This commit enables support for DW_MMC running with driver model.
Signed-off-by: Lukasz Majewski <lukma@denx.de>
Tested-by: Anand Moon <linux.amoon@gmail.com>
The Exynos5422 is solely using DW MMC IP block to support eMMC/SD devices,
hence the SDHCI code doesn't need to be compiled it.
Convert CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG to Kconfig
Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
Reviewed-by: Lukasz Majewski <lukma@denx.de>
Reviewed-by: Petr Vorel <petr.vorel@gmail.com>
Reviewed-by: Petr Vorel <petr.vorel at gmail.com>
On the NIOS2 and Xtensa architectures, we do not have
CONFIG_SYS_TEXT_BASE set. This is a strict migration of the current
values into the defconfig and removing them from the headers.
I did not attempt to add more default values in and for now will leave
that to maintainers.
This commit moves USB_FUNCTION_THOR config to Kconfig.
Acked-by: Michal Simek <michal.simek@xilinx.com>
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
Enable the CONFIG_CMD_REGULATOR and CONFIG_DM_REGULATOR_S2MPS11.
Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
Odroid HC1 board is based on Odroid XU4 board, but it has no HDMI,
no eMMC, no build-in USB3.0 hub, no extension port pins, and no GPIO
button. USB3.0 ports are used for build-in JMicron USB to SATA bridge
and Gigabit R8152 ethernet chips. HC1 uses only passive cooling.
This patch also updates Odroid's ADCmax array and reduces ADC tolerance
to 1% to ensure that XU4 and HC1 revisions are properly detected.
I've tested this with XU3, XU3-lite, XU4 and HC1 boards. In case of my test
boards I got following values from ADC register: 372, 370, 1281 and 1313.
Tested-by: Krzysztof Kozlowski <krzk@kernel.org>
We add the various SMC91XX symbols to drivers/net/Kconfig and then this
converts the following to Kconfig:
CONFIG_SMC911X
CONFIG_SMC911X_BASE
CONFIG_SMC911X_16_BIT
CONFIG_SMC911X_32_BIT
[trini: Apply to the rest of the tree, re-squash old and new patch]
Having this as a 'default y' is rather annoying because it doesn't
actually compile unless other options are defined in the board header:
../cmd/bootm.c: In function 'do_imls_nor':
../cmd/bootm.c:330:7: error: 'CONFIG_SYS_MAX_FLASH_BANKS' undeclared (first use in this function); did you mean 'CONFIG_SYS_MAX_FLASH_SECT'?
i < CONFIG_SYS_MAX_FLASH_BANKS; ++i, ++info) {
Make it 'default n' so people who develop new boards that start from a
blank defconfig have one less compilation failure to debug.
The g_dnl USB settings for the vendor ID, product ID and manufacturer are
actually common settings that can and should be shared by all the gadgets.
Make them common by renaming them, and convert all the users.
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
CONFIG_USB_HOST_ETHER is the framework that the drivers are dependent on
USB_HOST_ETHER. Use this as a menu and move the existing LAN75XX and
LAN78XX options under new menu. Finally update the defconfigs that need
CONFIG_USB_HOST_ETHER.
Signed-off-by: Chris Packham <judge.packham@gmail.com>
CONFIG_CMD_THOR_DOWNLOAD
Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
CONFIG_ENV_IS_IN_MMC
CONFIG_ENV_IS_IN_NAND
CONFIG_ENV_IS_IN_UBI
CONFIG_ENV_IS_NOWHERE
In fact this already exists for sunxi as a 'choice' config. However not
all the choices are available in Kconfig yet so we cannot use that. It
would lead to more than one option being set.
In addition, one purpose of this series is to allow the environment to be
stored in more than one place. So the existing choice is converted to a
normal config allowing each option to be set independently.
There are not many opportunities for Kconfig updates to reduce the size of
this patch. This was tested with
./tools/moveconfig.py -i CONFIG_ENV_IS_IN_MMC
And then manual updates. This is because for CHAIN_OF_TRUST boards they
can only have ENV_IS_NOWHERE set, so we enforce that via Kconfig logic
now.
Remove the CONFIG_I2C_COMPAT, instead enable the CONFIG_SYS_I2C_S3C24X0.
Migrate the rest of the users of CONFIG_USB_EHCI_HCD over to Kconfig.
For a few SoCs, imply or default y this if USB is enabled. In some
cases we had not already migrated to CONFIG_USB so do that as well.
This commit was created as follows:
[1] Rename the option with the following command:
find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \
-type f -print | xargs sed -i -e 's/CONFIG_DWMMC/CONFIG_MMC_DW/g'
[2] create the entry for MMC_DW in drivers/mmc/Kconfig
(the prompt and help were copied from Linux)
[3] run "tools/moveconfig.py -y MMC_DW"
[4] add "depends on MMC_DW" to the MMC_DW_ROCKCHIP entry
[5] Clean-up doc/README.socfpga by hand
While I moved the options, I also renamed them so that they are all
prefixed with MMC_SDHCI_.
This commit was created in the following steps.
[1] Rename with the following command
s/CONFIG_MMC_SDMA/CONFIG_MMC_SDHCI_SDMA/g
s/CONFIG_BCM2835_SDHCI/CONFIG_MMC_SDHCI_BCM2835/g
s/CONFIG_KONA_SDHCI/CONFIG_MMC_SDHCI_KONA/g
s/CONFIG_MV_SDHCI/CONFIG_MMC_SDHCI_MV/g
s/CONFIG_S5P_SDHCI/CONFIG_MMC_SDHCI_S5P/g
s/CONFIG_SPEAR_SDHCI/CONFIG_MMC_SDHCI_SPEAR/g
[2] create the Kconfig entries in drivers/mmc/Kconfig
[3] Move the options by the following command
tools/moveconfig.py -y MMC_SDHCI_SDMA MMC_SDHCI_BCM2835 \
MMC_SDHCI_KONA MMC_SDHCI_MV MMC_SDHCI_S5P MMC_SDHCI_SPEAR
[4] Sort drivers/mmc/Makefile for readability
Move CONFIG_SDHCI to Kconfig and rename it to CONFIG_MMC_SDHCI.
My motivation for the rename is, ultimately, to make all the MMC
options prefixed with MMC_ and SDHCI options with MMC_SDHCI_,
like Linux.
[1] Rename the config option with the following command:
-type f -print | xargs sed -i -e 's/CONFIG_SDHCI/CONFIG_MMC_SDHCI/g'
[2] create the entry for MMC_SDHCI in drivers/mmc/Kconfig
[3] run "tools/moveconfig.py -y MMC_SDHCI"
[4] add "depends on MMC_SDHCI" to existing SDHCI driver entries
Generated by "tools/moveconfig -s".
This will make config moves easier.
A number of platforms had been using the distro default feature before
it was moved to Kconfig but did not enable the new Kconfig option when
it was enabled. This caused a regression in terms of features and this
introduces breakage when more things move to Kconfig.
CONFIG_SYS_CONSOLE_IS_IN_ENV
CONFIG_CONSOLE_MUX
[trini: Re-order, re-migrate]
Move these option to Kconfig and tidy up existing uses.
The Power PC boards don't have a suitable common element: the common header
files don't appear to line up with the Kconfig files as far as I can tell.
This results in a lot of defconfig changes.
Reviewed-by: Jagan Teki <jteki@openedev.com>
[trini: Re-migrate, update common/console.c logic]
Introduce a hidden USB_FUNCTION_DFU Kconfig option and select it for
CMD_DFU (as we must have the DFU command enabled to do anything DFU).
Make all of the entries in drivers/dfu/Kconfig depend on CMD_DFU and add
options for all of the back end choices that DFU can make use of.
Cc: Lukasz Majewski <l.majewski@samsung.com>
Acked-by: Lukasz Majewski <l.majewski@samsung.com>
Move the config IDENT_STRING to Kconfig and migrate all boards
[sivadur: Migrate zynq boards]
Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
[trini: Update configs, add some default to sunxi Kconfig]
In some cases we were missing CONFIG_USB=y so enable that when needed.
Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
With updated moveconfig.py and an better default, re-generate
the migration of BOOTDELAY to the defconfig.
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
move CONFIG_BOOTDELAY into a Kconfig option. Used for this
purpose the moveconfig.py tool in tools.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
configs/peach-pi_defconfig
configs/peach-pit_defconfig
Create an entry for "config USB_XHCI_DWC3" in Kconfig and
switch over to it for all boards.
Move CONFIG_USB_XHCI to defconfig files for all boards, renaming it
into CONFIG_USB_XHCI_HCD.
As commented in the help of "config USB_XHCI" entry, this has been
a TODO for a long time; now CONFIG_USB_XHCI_HCD and CONFIG_USB_XHCI
have been unified in favor of the former.
Note:
Some boards define CONFIG_USB_XHCI in their headers without
CONFIG_USB, which does not meet the "depends on" in Kconfig.
I added CONFIG_USB=y for those boards when converting.
Otherwise, they would fail to build.
The existing Exynos 32-bit platform support needs to be realigned in
order to support newer 64-bit Exynos platforms. The driver model will
be utlized for drivers on the 64-bit Exynos platforms and so some of
the older platform support code would not be required for the newer
Signed-off-by: Thomas Abraham <thomas.ab@samsung.com>
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
And also reformat defconfigs using "make savedefconfig" rule.
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
Description was borrowed from kernel dwc3 Kconfig.
While at it, remove obsolete CONFIG_USBDOWNLOAD_GADGET option from some
config headers. This is also probably fixes am335x_baltos board.
Move CONFIG_USB_GADGET_DUALSPEED option to Kconfig and
make all UDC controllers select USB_GADGET_DUALSPEED:
- add next options to Kconfig selecting USB_GADGET_DUALSPEED:
- USB_GADGET_ATMEL_USBA
- USB_GADGET_DWC2_OTG
- USB_DWC3
- CI_UDC
- make USB_MUSB_GADGET select USB_GADGET_DUALSPEED
While at it, make some related fixes:
- remove DUALSPEED from configs that don't enable gadget support:
- kwb.h
- tseries.h
- add missing USB_GADGET option to next configs:
- novena_defconfig
- pcm051_rev*_defconfig
- xfi3_defconfig
The description was borrowed from kernel. "tristate" type was changed
to "bool" (I believe we don't support modules for u-boot yet, right?).
CONFIG_USB_GADGET requires CONFIG_USB to be defined too, so add it along
as well.
Definitions were added to defconfig files in a way that
"make savedefconfig" generates exactly the same file as used defconfig.
[trini: Add zynq_zc702 conversion]
There are already two FIT options in Kconfig but the CONFIG options are
still in the header files. We need to do a proper move to fix this.
Move these options to Kconfig and tidy up board configuration:
CONFIG_FIT
CONFIG_OF_BOARD_SETUP
CONFIG_OF_SYSTEM_SETUP
CONFIG_FIT_SIGNATURE
CONFIG_FIT_BEST_MATCH
CONFIG_FIT_VERBOSE
CONFIG_OF_STDOUT_VIA_ALIAS
CONFIG_RSA
Unfortunately the first one is a little complicated. We need to make sure
this option is not enabled in SPL by this change. Also this option is
enabled automatically in the host builds by defining CONFIG_FIT in the
image.h file. To solve this, add a new IMAGE_USE_FIT #define which can
be used in files that are built on the host but must also build for U-Boot
and SPL.
Note: Masahiro's moveconfig.py script is amazing.
[trini: Add microblaze change, various configs/ re-applies]
Add CMD_GPIO to Kconfig and run tools/moveconfig.py .
This commit adds additional file with implementation of board
detection code for Odroid-XU3/XU4.
The detection depends on compatible found in fdt:
- "samsung,exynos5" - uses Exynos5 generic code
- "samsung,odroidxu3" - try detect XU3 revision
There are few revisions of Odroid XU3/XU4, each can be detected
by checking the value of channel 9 of built-in ADC:
Rev ADC Board
0.1 0 XU3 0.1
0.2 372 XU3 0.2 | XU3L - no DISPLAYPORT
0.3 1280 XU4 0.1
The detection code depends on the ADC+10% value.
Implementation of functions:
- set_board_type() - read ADC and set type
- get_board_rev() - returns board revision: 1..3
- get_board_type() - returns board type string
Additional functions with return values of bool:
- board_is_generic() - true if found compatible "samsung,exynos5"
but not "samsung,odroidxu3"
- board_is_odroidxu3() - true if found compatible "samsung,odroidxu3"
and one of XU3 revision.
- board_is_odroidxu4() - true if found compatible "samsung,odroidxu3"
and XU4 revision.
After I2C controller init, the get_board_type() can check
if the XU3 board is a "Lite" variant, by probing chip
0x40 on I2C0 (INA231 - exists only on non-lite).
This is useful for setting fdt file name at misc_init_r().
Enabled configs:
- CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG
- CONFIG_ODROID_REV_AIN
- CONFIG_REVISION_TAG
- CONFIG_BOARD_TYPES
Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com>
Some boards' defconfigs are disordered. Reorder them.
