CONFIG_SUPPORT_EMMC_RPMB
This fixes a few platforms where the option was not taking effect as
intended.
CONFIG_CONS_INDEX
CONFIG_DEBUG_UART_CLOCK
CONFIG_FSL_TZPC_BP147
CONFIG_GENERIC_ATMEL_MCI
CONFIG_IDENT_STRING
CONFIG_LIBATA
CONFIG_LNX_KRNL_IMG_TEXT_OFFSET_BASE
CONFIG_LPC32XX_GPIO
CONFIG_MP
CONFIG_MPC8XXX_GPIO
CONFIG_MTD_PARTITIONS
CONFIG_MVGBE
CONFIG_MXC_GPIO
CONFIG_NR_DRAM_BANKS
CONFIG_OF_BOARD_SETUP
CONFIG_OF_STDOUT_VIA_ALIAS
CONFIG_OF_SYSTEM_SETUP
CONFIG_PREBOOT
CONFIG_ROCKCHIP_SERIAL
CONFIG_RTC_ENABLE_32KHZ_OUTPUT
CONFIG_RTC_MV
CONFIG_SCSI_AHCI
CONFIG_SF_DEFAULT_BUS
CONFIG_SF_DEFAULT_CS
CONFIG_SF_DEFAULT_SPEED
CONFIG_SOFT_SPI
CONFIG_SPI_FLASH_EON
CONFIG_SPI_FLASH_MACRONIX
CONFIG_SPI_FLASH_MTD
CONFIG_SPI_FLASH_SPANSION
CONFIG_SPI_FLASH_SST
CONFIG_SPI_FLASH_STMICRO
CONFIG_SUPPORT_RAW_INITRD
CONFIG_SYS_ARCH_TIMER
CONFIG_SYS_BOARD
CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE
CONFIG_SYS_DCACHE_OFF
CONFIG_SYS_FDT_SAVE_ADDRESS
CONFIG_SYS_FLASH_CFI
CONFIG_SYS_FSL_ERRATUM_ESDHC135
CONFIG_SYS_HAS_SERDES
CONFIG_SYS_L2CACHE_OFF
CONFIG_SYS_LITTLE_ENDIAN
CONFIG_SYS_LOAD_ADDR
CONFIG_SYS_MMCSD_FS_BOOT_PARTITION
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR
CONFIG_SYS_NS16550
CONFIG_SYS_PLLFIN
CONFIG_SYS_SPI_U_BOOT_OFFS
CONFIG_TIMER_SYS_TICK_CH
CONFIG_USB_EHCI_FSL
CONFIG_U_QE
CONFIG_VERSION_VARIABLE
CONFIG_ENV_SPI_BUS
CONFIG_ENV_SPI_CS
CONFIG_ENV_SPI_MAX_HZ
CONFIG_ENV_SPI_MODE
As part of this, we use Kconfig to provide the defaults now that were
done in include/spi_flash.h. We also in some cases change from using
CONFIG_ENV_SPI_FOO to CONFIG_SF_DEFAULT_FOO as those were the values in
use anyhow as ENV was not enabled.
Use this new Kconfig instead of OF_BOARD, so we know for sure which boards
obtain their devicetree from a prior stage. Leave sandbox alone since it
does not. Also don't touch xilinx_versal_virt since it does not have a
specific TARGET Kconfig.
This option implies OF_BOARD for now, but with future work standard
passage may be used instead.
[trini: Add rpi_4_32b and rpi_arm64 to the list of boards converted]
Add an empty file to prevent build errors when building with
CONFIG_OF_SEPARATE enabled.
Unfortunately there are no build instructions in the U-Boot tree to enable
a real file to be created.
CONFIG_LAST_STAGE_INIT
CONFIG_ENV_IS_IN_SPI_FLASH
CONFIG_ENV_IS_NOWHERE
CONFIG_ENV_OFFSET
CONFIG_ENV_OVERWRITE
CONFIG_ENV_SECT_SIZE
CONFIG_SYS_MMC_ENV_DEV
CONFIG_SYS_MMC_ENV_PART
CONFIG_SUPPORT_EMMC_BOOT
CONFIG_SYS_MALLOC_LEN
Acked-by: Sean Anderson <seanga2@gmail.com>
Reviewed-by: Rick Chen <rick@andestech.com>
Now that we have consistent usage, migrate this symbol to Kconfig.
The following boards no longer need CONFIG_DM_PCI_COMPAT enabled, so
remove that.
TFTP transfer size can be used to re-size the TFTP progress bar on
single line based on the server reported file size. The support for
this has been around from 2019, but it was never converted to proper
Kconfig.
While adding this new Kconfig, enable it by default for OMAP2+ and K3
devices also.
Signed-off-by: Tero Kristo <kristo@kernel.org>
Enable the now included network drivers in the currently supported
Marvell Octeon TX & TX2 boards.
Cc: Aaron Williams <awilliams@marvell.com>
Cc: Suneel Garapati <sgarapati@marvell.com>
Cc: Chandrakala Chavva <cchavva@marvell.com>
Enable WDT command for Octeon TX/TX2 boards.
- Add basic Marvell/Cavium OcteonTX/TX2 support (Suneel)
- Infrastructure changes to PCI uclass to support these SoC's (Suneel)
- Add PCI, MMC & watchdog driver drivers for OcteonTX/TX2 (Suneel)
- Increase CONFIG_SYS_MALLOC_F_LEN for qemu-x86 (Stefan)
This patch adds support for all OcteonTX2 96xx/95xx
boards from Marvell.
For 96xx boards, use octeontx_96xx_defconfig and
for 95xx boards, use octeontx_95xx_defconfig.
Signed-off-by: Suneel Garapati <sgarapati@marvell.com>
