The current name is inconsistent with SPL which uses CONFIG_SPL_TEXT_BASE
and this makes it imposible to use CONFIG_VAL().
Rename it to resolve this problem.
This patch adds a fixup function related to a PCIe FLR (Function Level
Reset) problem on the NIC23 PCIe board. This function is imported from
the Marvell Octeon 2013 U-Boot version as a (nearly) verbatim copy. It
uses the newly introduced cyclic infrastructure, so that this function
gets called every 100us, which is needed to detect this FLR issue.
Signed-off-by: Aaron Williams <awilliams@marvell.com>
CONFIG_SYS_BOOTM_LEN
As part of this, rework error handling in boot/bootm.c so that we pass
the buffer size to handle_decomp_error as CONFIG_SYS_BOOTM_LEN will not
be available to host tools but we do know the size that we passed to
malloc().
Cc: Soeren Moch <smoch@web.de>
CONFIG_LBA48
CONFIG_SYS_64BIT_LBA
CONFIG_SYS_CBSIZE
CONFIG_SYS_PBSIZE
This patch enables the Kconfig symbols needed for full ethernet support
on the NIC23. Additionally board specific setup is done, mostly GPIOs
related to SFP / GPIO configuration. With this, ethernet can be used on
this board. Here an example of a tftp load:
=> tftp ffffffff81000000 big
Using ethernet-mac-nexus@11800e2000000 device
TFTP from server 192.168.1.5; our IP address is 192.168.1.247
Filename 'big'.
Load address: 0xffffffff81000000
Loading: ################################################## 10 MiB
9.7 MiB/s
done
Bytes transferred = 10485760 (a00000 hex)
CONFIG_SYS_MALLOC_LEN
Acked-by: Sean Anderson <seanga2@gmail.com>
Reviewed-by: Rick Chen <rick@andestech.com>
Now that we have consistent usage, migrate this symbol to Kconfig.
This patch adds the basic support for the PCIe target board equipped
with the Octeon III CN2350 SoC.
