Now that those common Allwinner config symbols are defined automatically
for all boards in their Kconfig files, we can remove the now redundant
definitions from the boards' _defconfig files.
Some boards had a differing definiton for some of those symbols, it
looks like mostly to "merge races" when the symbol was introduced (new
board *_defconfig file missed the "add symbol to all files" patch).
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Acked-by: Maxime Ripard <mripard@kernel.org>
Tested-by: Jagan Teki <jagan@amarulasolutions.com> # Amarula A64-Relic
Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
For Allwinner SoCs the CONFIG_SYS_SPI_U_BOOT_OFFS value is not really a
board choice: The boot ROM only loads the SPL from offset 0 of the SPI
NOR flash, and loads at most 32KB. This is a similar situation as on MMC,
so consequently we create our "joint" image (SPL + U-Boot proper) with
that 32KB offset during the build.
So define the value of this symbol to be 32KB by default for every
Allwinner SoC. This removes the definition of this symbol from the
_defconfig files, and avoids every board to define this over and over
again.
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
Signed-off-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
[trini: Expose this for SPL_SPI_SUNXI for now]
CONFIG_USE_PREBOOT
CONFIG_PREBOOT
Both are together in one commit, since otherwise the former causes kconfig
to define the latter, which gives duplicate symbol errors.
Includes a manual fixup for CONFIG_PREBOOT in ids8313_defconfig since the
backslash lands in the wrong place. Similarly with socfpga_vining_fpga.
The choice of the SPL_TEXT_BASE is not really a decision that should be
specified by each board's defconfig, as this setting is actually
dictated by the SoC's memory map and the BootROM behaviour.
To make this obvious and reduce the clutter in the defconfig files,
let's specify the SoC constraints in the Kconfig stanza.
This allows us to remove these lines from the defconfig files again.
Acked-by: Maxime Ripard <maxime.ripard@bootlin.com>
Moved CONFIG_SPL_TEXT_BASE to common/spl/Kconfig and migrate existing
values.
Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
[trini: Re-run migration]
Oceanic 5205 5inMFD is a 5 inch Multi function display baseboard
designed to mount SoPine SOM.
Key features:
- Allwinner A64 Cortex-A53
- Mali-400MP2 GPU
- AXP803 PMIC
- 2GB DDR3 RAM
- SD Slot
- SPI-NOR flash
- EMAC, RTL8211E
- MCP2515 CAN
- 4-lane, MIPI-DSI panel
- Goodix 911 CTP
- USB Host
- 12V DC power supply
Linux commit details about the sun50i-a64-oceanic-5205-5inmfd.dts sync:
"arm64: allwinner: a64: Add Oceanic 5205 5inMFD initial support"
(sha1: 00f7980a3bd53d12abc34f68146a8eed0e894248)
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
