path: root/configs/nyan-big_defconfig
2016-12-03Enable DISTRO_DEFAULT on platforms that missed it beforeTom Rini
A number of platforms had been using the distro default feature before it was moved to Kconfig but did not enable the new Kconfig option when it was enabled. This caused a regression in terms of features and this introduces breakage when more things move to Kconfig. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_SYS_STDIO_DEREGISTER to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SYS_STDIO_DEREGISTER This option should never be enabled in SPL, so use CONFIG_IS_ENABLED(SYS_STDIO_DEREGISTER) when checking the option. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Re-sync] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-11dm: mmc: Enable DM_MMC_OPS by default with DM_MMCSimon Glass
These two options go together and it is best to do the conversion in one step. So enable DM_MMC_OPS by default if DM_MMC is enabled. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-11dm: blk: Enable CONFIG_BLK if DM_MMC is enabledSimon Glass
To speed up conversion to CONFIG_BLK, enable it by default when DM_MMC is enabled. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-09-27dfu: Migrate to KconfigTom Rini
Introduce a hidden USB_FUNCTION_DFU Kconfig option and select it for CMD_DFU (as we must have the DFU command enabled to do anything DFU). Make all of the entries in drivers/dfu/Kconfig depend on CMD_DFU and add options for all of the back end choices that DFU can make use of. Cc: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Lukasz Majewski <l.majewski@samsung.com>
2016-04-20usb: gadget Move: CONFIG_G_DNL_* to KconfigSam Protsenko
And also reformat defconfigs using "make savedefconfig" rule. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_DOWNLOAD to KconfigSam Protsenko
While at it, remove obsolete CONFIG_USBDOWNLOAD_GADGET option from some config headers. This is also probably fixes am335x_baltos board. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_DUALSPEED to KconfigSam Protsenko
Move CONFIG_USB_GADGET_DUALSPEED option to Kconfig and make all UDC controllers select USB_GADGET_DUALSPEED: - add next options to Kconfig selecting USB_GADGET_DUALSPEED: - USB_GADGET_ATMEL_USBA - USB_GADGET_DWC2_OTG - USB_DWC3 - CI_UDC - make USB_MUSB_GADGET select USB_GADGET_DUALSPEED While at it, make some related fixes: - remove DUALSPEED from configs that don't enable gadget support: - kwb.h - tseries.h - add missing USB_GADGET option to next configs: - novena_defconfig - pcm051_rev*_defconfig - xfi3_defconfig Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-03-25usb: gadget: Move CONFIG_USB_GADGET to KconfigSam Protsenko
The description was borrowed from kernel. "tristate" type was changed to "bool" (I believe we don't support modules for u-boot yet, right?). CONFIG_USB_GADGET requires CONFIG_USB to be defined too, so add it along as well. Definitions were added to defconfig files in a way that "make savedefconfig" generates exactly the same file as used defconfig. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> [trini: Add zynq_zc702 conversion] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-03-22defconfig: Reorder boards' defconfig filesBin Meng
Some boards' defconfig files are out of order. Clean this up. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-02-16tegra: Convert CONFIG_PWM_TEGRA to KconfigSimon Glass
Move this option to Kconfig and clean up the header files. Adjust the only user (the LCD driver) to work with the new driver. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-02-16tegra: nyan-big: Move the LCD driver to driver modelSimon Glass
Adjust the driver to use driver model. The SOR becomes a bridge device. We use the normal simple_panel driver to handle the display itself. We also need to enable some options such as regulators, PWMs and DM_VIDEO itself. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-01-26video: add CONFIG_I2C_EDID and disable CONFIG_DISPLAY by defaultAnatolij Gustschin
Enabling CONFIG_DISPLAY breaks building for some architectures (microblaze-generic), so we disable CONFIG_DISPLAY in Kconfig by default and enable this option in defconfigs. CONFIG_DISPLAY depends on CONFIG_I2C_EDID, so add and enable it in defconfigs, too. Signed-off-by: Anatolij Gustschin <agust@denx.de> Reported-by: Bin Meng <bmeng.cn@gmail.com> Cc: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2016-01-21dm: video: Repurpose the 'displayport' uclass to 'display'Simon Glass
The current DisplayPort uclass is too specific. The operations it provides are shared with other types of output devices, such as HDMI and LVDS LCD displays. Generalise the uclass so that it can be used with these devices as well. Adjust the uclass to handle the EDID reading and conversion to display_timing internally. Also update nyan-big which is affected by this. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-10-23dm: tpm: Move tpm_tis_i2c to tpm_i2c_infineonChristophe Ricard
As there is no TCG specification or recommendation for i2c TPM 1.2, move tpm_tis_i2c driver to tpm_i2c_infineon. Other tpm vendors like Atmel or STMicroelectronics may have a different transport protocol for i2c. Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-08-31tegra: nyan: Enable TPM command and driverSimon Glass
The TPM is listed in the device tree. Enable the driver and 'tpm' command so that it can be used. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Christophe Ricard <christophe-h.ricard@st.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2015-08-21Tidy up some defconfig filesSimon Glass
Several files are out of order. This means that when the moveconfig tool moves CONFIG options to Kconfig it generates a large diff. To avoid this, reorder the files first. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-08-05Tegra: spi: Move TEGRA114_SPI switch to defconfigsTom Warren
All T114+ Tegra boards should be using the Kconfig TEGRA114_SPI switch. Remove it from include/config and put it into defconfig. Also removed unused TEGRA114_SPI_CTRLS from T114+ configs. All Tegra SoCs build OK with this change. Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-06-09dm: tegra: cros_ec: Enable Chrome OS EC on Nyan-bigSimon Glass
Enable the EC and keyboard, using the SPI bus. The EC driver requires a particular format and a deactivation delay. Also U-Boot does not support interrupts. For now, adjust the device tree to comply. At some point we should tidy this up to support interrupts and make tegra and exynos use the same setup. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-05-13tegra: config: nyan-big: Enable LCDSimon Glass
Add the PMIC, LCD settings, PWM and also show the board info at the top of the LCD when starting up. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-12-11ARM: tegra: Add support for nyan-big boardAllen Martin
Nyan-big is a Tegra124 clamshell board that is very similar to venice2, but it has a different panel, the sdcard cd and wp sense are flipped, and it has a different revision of the AS3722 PMIC. This is the Acer Chromebook 13 CB5-311-T7NN (13.3-inch HD, NVIDIA Tegra K1, 2GB). The display is not currently supported, so it should boot on other nyan-based Chromebooks also, but only the device tree for nyan-big is provided here. The device tree file is from Linux but with features removed which are unlikely to be supported in U-Boot soon (regulators, pinmux). Also the addresses are updated to 32-bit. Signed-off-by: Allen Martin <amartin@nvidia.com> Signed-off-by: Simon Glass <sjg@chromium.org> (rebase, change to 'nyan-big', fix pinmux that resets nyan-big)
