path: root/configs/nx25-ae250_defconfig
2018-02-10configs: Resync with savedefconfigTom Rini
2018-01-12riscv: defconfig: Add nx25-ae250 defconfig to support RISC-VRick Chen
Add nx25-ae250 default configuration for RISC-V Signed-off-by: Rick Chen <rick@andestech.com> Signed-off-by: Rick Chen <rickchen36@gmail.com> Signed-off-by: Greentime Hu <green.hu@gmail.com>
