Now that we have consistent usage, migrate this symbol to Kconfig.
Reviewed-by: Rick Chen <rick@andestech.com>
It's a very rare if at all existing occasion when ARC CPU template
is used as is w/o any changes - in the end it's a beauty and competitive
advantage of ARC cores to be tailored for a particular use-case - and
so it doesn't make a lot of sense to offer template-based "-mcpu" selection.
Given for each and every platform we end-up adding quite a few more flags
it's logical to move "-mcpu" selection to platform's definition as well
which we exactly do here.
Signed-off-by: Eugeniy Paltsev <Eugeniy.Paltsev@synopsys.com>
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
We don't have yet any brc700 or big-enadian platforms with networking
support to run this particular configuration.
Whenever QEMU for ARC supports arc700 or big-endian targets we may revisit
this one.
Since v2019.06 DesingWare nSIM supports DesignWare UART simulation
and so we may switch from pretty unusual ARC UART to much more standard
DesignWare UART (which in case of U-Boot is just an ordinary 16650 UART).
This among other things makes built dinaries compatible with our other
platforms to name a few: FPGA-based HAPS boards, QEMU and even ZeBU.
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
One step closer to completely Kconfig-driven target configuration in
U-Boot :)
Having this as a 'default y' is rather annoying because it doesn't
actually compile unless other options are defined in the board header:
../cmd/bootm.c: In function 'do_imls_nor':
../cmd/bootm.c:330:7: error: 'CONFIG_SYS_MAX_FLASH_BANKS' undeclared (first use in this function); did you mean 'CONFIG_SYS_MAX_FLASH_SECT'?
i < CONFIG_SYS_MAX_FLASH_BANKS; ++i, ++info) {
Make it 'default n' so people who develop new boards that start from a
blank defconfig have one less compilation failure to debug.
Also introduce CONFIG_USE_BOOTARGS option so we can control if
CONFIG_BOOTARGS defined at all.
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
[trini: Resync r8a779[56]_ulcb, various ls10xx targets]
CONFIG_ENV_IS_IN_MMC
CONFIG_ENV_IS_IN_NAND
CONFIG_ENV_IS_IN_UBI
CONFIG_ENV_IS_NOWHERE
In fact this already exists for sunxi as a 'choice' config. However not
all the choices are available in Kconfig yet so we cannot use that. It
would lead to more than one option being set.
In addition, one purpose of this series is to allow the environment to be
stored in more than one place. So the existing choice is converted to a
normal config allowing each option to be set independently.
There are not many opportunities for Kconfig updates to reduce the size of
this patch. This was tested with
./tools/moveconfig.py -i CONFIG_ENV_IS_IN_MMC
And then manual updates. This is because for CHAIN_OF_TRUST boards they
can only have ENV_IS_NOWHERE set, so we enforce that via Kconfig logic
now.
ARCangel was one of the main development boards back in the day but
now it's gone and replaced by other boards like ARC SDP.
But we also used to have simulation platform very similar to ARCangel4
in terms of CPU settings as well as basic IO like UART. Even though
ARCangel4 is long gone now we have a replacement for simulation which is
a plain or stand-alone nSIM and Free nSIM.
Note Free nSIM is available for download here:
https://www.synopsys.com/cgi-bin/dwarcnsim/req1.cgi
And while at it:
* Finally switch hex numerical values in nsim.h to defines from
include/linux/sizes.h
* Add defconfigs with ARC HS38 cores
* Recreated all defconfigs with savedefconfig
