path: root/configs/nsim_700_defconfig
2020-02-12ARC: rework setting of ARC CPU specific compiler optionsEugeniy Paltsev
It's a very rare if at all existing occasion when ARC CPU template is used as is w/o any changes - in the end it's a beauty and competitive advantage of ARC cores to be tailored for a particular use-case - and so it doesn't make a lot of sense to offer template-based "-mcpu" selection. Given for each and every platform we end-up adding quite a few more flags it's logical to move "-mcpu" selection to platform's definition as well which we exactly do here. Signed-off-by: Eugeniy Paltsev <Eugeniy.Paltsev@synopsys.com> Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2020-02-12ARC: nsim_{700|700be|hs38be}_defconfigs: Disable networkingAlexey Brodkin
We don't have yet any brc700 or big-enadian platforms with networking support to run this particular configuration. Whenever QEMU for ARC supports arc700 or big-endian targets we may revisit this one. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2020-02-12ARC: nSIM: switch from ARC UART to DW UARTAlexey Brodkin
Since v2019.06 DesingWare nSIM supports DesignWare UART simulation and so we may switch from pretty unusual ARC UART to much more standard DesignWare UART (which in case of U-Boot is just an ordinary 16650 UART). This among other things makes built dinaries compatible with our other platforms to name a few: FPGA-based HAPS boards, QEMU and even ZeBU. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2019-12-04configs: Resync with savedefconfigTom Rini
2018-05-24ARC: Enable debug UART on nSIM boardsAlexey Brodkin
2018-05-24serial: Convert ARC_SERIAL to KconfigAlexey Brodkin
One step closer to completely Kconfig-driven target configuration in U-Boot :) Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2016-08-05arc: Rename ARCangel4 board to nSIMAlexey Brodkin
ARCangel was one of the main development boards back in the day but now it's gone and replaced by other boards like ARC SDP. But we also used to have simulation platform very similar to ARCangel4 in terms of CPU settings as well as basic IO like UART. Even though ARCangel4 is long gone now we have a replacement for simulation which is a plain or stand-alone nSIM and Free nSIM. Note Free nSIM is available for download here: https://www.synopsys.com/cgi-bin/dwarcnsim/req1.cgi And while at it: * Finally switch hex numerical values in nsim.h to defines from include/linux/sizes.h * Add defconfigs with ARC HS38 cores * Recreated all defconfigs with savedefconfig Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
