path: root/configs/nsa310s_defconfig
2017-12-12ata: Migrate CONFIG_MVSATA_IDE to KconfigTuomas Tynkkynen
2017-05-22Convert CONFIG_LZMA to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_LZMA Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_JFFS2 to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_JFFS2 Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_IDE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_IDE Signed-off-by: Simon Glass <sjg@chromium.org>
2016-09-26kconfig: introduce kconfig for UBIHeiko Schocher
move the UBI config options into Kconfig. Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Andrew F. Davis <afd@ti.com> Reviewed by: Evgeni Dobrev <evgeni at studio-punkt.com>
2016-03-14Correct defconfig orderingSimon Glass
Various boards have the wrong Kconfig ordering now. To avoid a misleading diff in the next patch, reorder the configuration correctly. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-11-29arm: kirkwood: add ZyXEL NSA310S deviceGerald Kerma
This patch add ZyXEL NSA310S 1-Bay Media Server The ZyXEL NSA310S device is a Kirkwood based NAS: - SoC: Marvell 88F6702 1000Mhz - SDRAM memory: 256MB DDR2 400Mhz - Gigabit ethernet: PHY Marvell 88E1318 - Flash memory: 128MB - 1 Power button - 1 Power LED (blue) - 4 Status LED (green) - 1 Copy/Sync button - 1 Reset button - 1 SATA II port - 2 USB 2.0 ports (front and back) - Smart fan Signed-off-by: Gerald Kerma <dreagle@doukki.net> Signed-off-by: Tony Dinh <mibodhi@gmail.com> Signed-off-by: Luka Perkov <luka.perkov@sartura.hr>
