path: root/configs/nhk8815_onenand_defconfig
2014-08-30nomadik: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the Nomadik board select menu to nomadik/Kconfig. Move also common settings (CONFIG_SYS_CPU="arm926ejs" and CONFIG_SYS_SOC="nomadik"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
