path: root/configs/netspace_lite_v2_defconfig
2018-02-13spi: Migrate CONFIG_KIRKWOOD_SPI to KconfigTuomas Tynkkynen
2017-12-12ata: Migrate CONFIG_MVSATA_IDE to KconfigTuomas Tynkkynen
2017-05-22Convert CONFIG_CMD_IDE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_IDE Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_EEPROM et al to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_EEPROM CONFIG_CMD_EEPROM_LAYOUT CONFIG_EEPROM_LAYOUT_HELP_STRING Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Rework Kconfig logic slightly, define EEPROM location on TI eval platforms] Signed-off-by: Tom Rini <trini@konsulko.com>
2014-08-30kirkwood: kconfig: refactor Kconfig and defconfigMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the KirkWood board select menu to kirkwood/Kconfig. Consolidate also common settings (CONFIG_SYS_CPU="arm926ejs" and CONFIG_SYS_SOC="kirkwood"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Prafulla Wadasdkar <prafulla@marvell.com> Cc: Luka Perkov <luka@openwrt.org>
