path: root/configs/netgear_dgnd3700v2_ram_defconfig
2020-01-22configs: Resync with savedefconfigTom Rini
2019-12-04configs: Resync with savedefconfigTom Rini
2019-09-23configs: Resync with savedefconfigTom Rini
2019-01-16MIPS: bmips: switch to CONFIG_OF_SEPARATEDaniel Schwierzeck
Fix the Kconfig warning to not use CONFIG_OF_EMBED in defconfigs. Based on https://patchwork.ozlabs.org/patch/1019791/ Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com> Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2018-12-19bmips: enable dgnd3700v2 enet supportÁlvaro Fernández Rojas
2018-03-21mips: bmips: add dgnd3700v2 usb supportÁlvaro Fernández Rojas
2018-03-21mips: bmips: select OF_EMBED for all boardsÁlvaro Fernández Rojas
2018-03-21MIPS: add BMIPS Netgear DGND3700v2 boardÁlvaro Fernández Rojas
