path: root/configs/netgear_cg3100d_ram_defconfig
2018-03-21mips: bmips: select OF_EMBED for all boardsÁlvaro Fernández Rojas
Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com>
2018-02-27Kconfig: cmd: Make networking command dependent on NETMichal Simek
Enable networking command only when NET is enabled. And remove selecting NET for CMD_NET Signed-off-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2018-01-24mips: bmips: enable the SPI flash on the Netgear CG3100DÁlvaro Fernández Rojas
It's a Spansion (s25fl064a) 8 MB SPI flash. Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Reviewed-by: Jagan Teki <jagan@openedev.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-31MIPS: add BMIPS Netgear CG3100D boardÁlvaro Fernández Rojas
Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
