path: root/configs/nanopi_neo_plus2_defconfig
2018-04-16part: Disable CONFIG_SPL_ISO_PARTITION by defaultAlexander Graf
We enabled CONFIG_ISO_PARTITION by default for distro boot, so that U-Boot could load distro images that usually get shipped as iso images. These images usually come with a board agnostic boot environment. However, there is very little point in having ISO support enabled (for anyone really) in SPL, as the whole idea of SPL is to load U-Boot proper which again is board specific. So the fact that we enable ISO support in U-Boot proper does not mean at all that we want ISO support in U-Boot SPL. Hence, let's remove the Kconfig dependency. Along the way, let's also clean up all those default configs that disabled SPL ISO support. Signed-off-by: Alexander Graf <agraf@suse.de>
2018-03-14sunxi: move CONFIG_SYS_TEXT_BASE out of defconfigsAndre Przywara
Commit 278b90ce786f ("configs: Migrate CONFIG_SYS_TEXT_BASE") made CONFIG_SYS_TEXT_BASE a proper Kconfig variable, with the consequence of moving the common definition shared by almost every sunxi board into 123 individual defconfig files. But the U-Boot start address for Allwinner boards is a platform decision which has been around for ages, so defining it in each *board* config file seems a bit over the top. Define the standard values (160MB into DRAM for most SoCs, with two SoC exceptions) if ARCH_SUNXI is selected, and delete the lines from the individual defconfigs. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Acked-by: Maxime Ripard <maxime.ripard@bootlin.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2018-02-10configs: Resync with savedefconfigTom Rini
2017-11-21sun50i: h5: Add NanoPi Neo Plus2 DT initial supportAntony Antony
Add initial DT for NanoPi NEO Plus2 by FriendlyARM - Allwinner quad core H5 Cortex A53 with an ARM Mali-450MP GPU - 1 GB DDR3 RAM - 8GB eMMC flash (Samsung KLM8G1WEPD-B031) - micro SD card slot - Gigabit Ethernet (external RTL8211E-VB-CG chip) - 802.11 b/g/n WiFi, Bluetooth 4.0 (Ampak AP6212A module) - 2x USB 2.0 host ports Signed-off-by: Antony Antony <antony@phenome.org> Reviewed-by: Jagan Teki <jagan@openedev.com>
