path: root/configs/nanopi_neo_defconfig
2016-09-20configs: Re-syncTom Rini
2016-09-18sunxi: Add defconfig and dts for the NanoPi NEOJelle van der Waa
The NanoPi NEO is a simple h3 board with 512MB RAM, ethernet, one usb and one usb OTG connector. Signed-off-by: Jelle van der Waa <jelle@vdwaa.nl> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
